2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Subwoofer upgrade alternative ?
      01-08-2016, 10:36 AM   #1
550Reasons
550Reasons's Avatar
Drives: F10 550i
on my lunch break bored browsing around I found this on ebay.
http://www.ebay.com/itm/Ampire-Subwo...4AAOxygPtS1XPf
not bad, 160$ for each speaker. (320$ shipped for both)
Seems like a cheaper alternative to Bavsound ones ? (500$ for both)
They are 100W RMS / 200W PEAK, same as Bavsound.
Translation:
Product description :
Finally the new NEO8 - BMW subwoofer comes to the lower seat assembly for BMW vehicles .
The newly developed chassis is much more durable and louder than the competition .
The basket has been optimized to accommodate a large neodymium magnet . In addition, the spider and dust cap was vented in order to achieve a higher capacity.
The subwoofer fits perfectly without any modifications to the standard mount under the front seats.
TECHNICAL SPECIFICATIONS
20cm ( 8 ' ' ) subwoofer for BMW
100 watts RMS / 200 watts max .
Fiber paper cone
ventilated dustcap
ventilated spider
Linear stroke: 10mm
Z : 4 Ohm
Re : 3.2 Ohm
IMPORTANT NOTE:
Some BMW Logic7 sound systems " Professional " basses were used with 8 Ohm impedance . If you install in these vehicles the NEO8 - BMW with 4 ohm impedance , the protection circuit will trip the Logic 7 amplifier at extreme volume levels .
Im really thinking about pulling the trigger on this, just waiting to see what you guys think.
2011 550i
2013 M5
2014 M5 CP
2016 550i
      01-08-2016, 01:21 PM   #2
Teddylongtooth
ZEROdoubleZERO
Teddylongtooth's Avatar
228
Drives: 2011 550i m sport
Get those puppies and do a review.
      01-08-2016, 02:29 PM   #3
550Reasons
550Reasons's Avatar
Drives: F10 550i
Im still recuperating from Christmas, so Id have to order them beginning of February
2011 550i
2013 M5
2014 M5 CP
2016 550i
      01-08-2016, 03:50 PM   #4
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
550Reasons...did you already upgrade your components? i'm going Gladen Extremes. i've read into those Ampire awhile back and they are about the same as the SWS8 earthquakes. most reviews said they're nice but still somewhat muddy on the excursion side because it's trying to do both mid/low
specs for the included Gladen 8" woofers
2x 225/150 rms (Woofer) into 2 ohms + 2x 150/100 rms (MHT) at 3 Ohms
great reviews on these as most guys from what they posted are excellent for mid bass! which is what i'm primarily using them for.
still leaving the duties for the low end freq for the subs in the trunk. just ordered 2 Kicker 40CWR124 1000W 12" Dual 4 ohm CompR for my Nissan Titan and if they sound good to me i'll end up getting another set for the Beemer!
      01-10-2016, 11:05 AM   #5
550Reasons
550Reasons's Avatar
Drives: F10 550i
No I havent upgraded anything yet, Im just trying to get a bit more bass.
Is this what your talking about ?
http://www.germaniks.com/speakers/gl...7x-e8x-e9x-fx/
2011 550i
2013 M5
2014 M5 CP
2016 550i
      01-10-2016, 02:05 PM   #6
lsturbointeg
It's these! Extremes handles a bit more power. Was looking into their Mosconi bundle as it includes the rear speakers too
Here's the Mosconi bundle...I'm checking to see if I can run a monoblock amp for the trunk subs through the Mosconi amp...I think I can?
http://www.germaniks.com/bmw-e60-e61...osconi-gladen/
This package for BMW E6x, E7x, E9x, F1x, F3x and more incudes the following:
- Amplifier Mosconi 60.6 (6 channels)
- Gladen speakers BMW 201 ALPHA
- 4 channels radio plug
- Rear speakers (Gladen RC 100)
- Fuse wiring kit
- Free remote BMW coding to HIFI (You must have a Windows laptop and a BMW OBD plug : You can buy the BMW plug from http://www.cable-shack.co.uk/ for example)
Amplifier's specifications
Target powers:
65 Watt per channel @ 4 Ohm
60 Watt x 4 @ 4 Ohm/ST + 230 Watt x 1 Ohm @ 4 Ohm/BTL
100 Watt per channel @ 2 Ohm
200 Watt BTL mode @ 4 Ohm
Input sensitivity: (Power rating ref)
0.34 V ÷ 15.57 V
Xover functions: (HIGH Pass or LOW Pass)
FRONT (45 ÷ 225 Hz – 12 dB/oct)
REAR (20 ÷ 225 Hz – 12 dB/oct)
LOW Pass
SUB (45 ÷ 225 Hz – 12 dB/oct)
Special Features:
Remote Volume Control (optional)
Front Stage Adjuster
Phase Shift 0° ÷ 180° (Rear)
High Low Adapter
F mix R
Size:
310x200x50 mm
Weight:
2,77 Kg
here's the spec on the Bimmertech amp
at 4 Ohms 8 x 55 Watts / 110 Watts
at 2 Ohms 8 x 70 Watts / 140 Watts
      01-11-2016, 01:30 AM   #7
msfive
Drives: 2015 5281
- Fuse wiring kit
Target powers:
0.34 V ÷ 15.57 V
LOW Pass
Special Features:
High Low Adapter
F mix R
Size:
310x200x50 mm
Weight:
2,77 Kg
If you willing to spend $1100 for that amp (+shipping & some tax maybe almost $1200) I would really think about helix it's 120 watts x6 & it have a processing build-in. If you shop around you would get it the same price. I think you be happier w/ sound with that power.
      01-11-2016, 06:47 AM   #8
lsturbointeg
That includes the speakers all around not just the amp
      01-11-2016, 08:52 AM   #9
Nelson@BimmerTech
Drives: 2014 M6 GC
But that amp doesn't have a built in dsp. You should be looking at this if you want to compare it to our amp http://www.germaniks.com/amplifiers-...i-d2-80-6-dsp/ and it's only 6 channels.
      03-20-2016, 08:31 AM   #10
2tek
Daddy Wagon
Ireland
14
Drives: G31
- Fuse wiring kit
Target powers:
0.34 V ÷ 15.57 V
LOW Pass
Special Features:
High Low Adapter
F mix R
Size:
310x200x50 mm
Weight:
2,77 Kg
Had these installed by germaniks himself and he also threw in coding for enhanced bluetooth for a token.
i drive a 2014 f10 and the difference is night and day.
best 1400 ive spent. i dj semi pro and my mates used to slag me about how flat the stock audio was.
i got the amp with dsp function. he changed both underseat subs, rear speakers, tweeters (my car didnt come with tweeters), front speakers. its a combo of gladen and mosconi products. (i have two amps installed)
      03-20-2016, 09:38 AM   #11
lsturbointeg
NICE! that's the plan for me but it sits at the bottom of my mods-list lol glad you dropped your insight and impression on these i almost went with the Bav's but at the time they didn't have the underseat replacements but i knew there was better out there as i'm running Focal K2's in my Titan so i wanted something like that in my Beemer. Nelson recommend the Jehnert's or Gladen's so that's the direction i'm goin in. why the need for 2 amps unless you're running subs in the trunk or is it powering the underseat subs?
      03-20-2016, 09:48 AM   #12
2tek
Daddy Wagon
Ireland
14
Drives: G31
He gave me an option of a single 6 channel amp to run all the speakers,think he mentioned it might be a bit underpowered so i opted for the two amp set up for more head room and incase i plan to run a separate sub in the trunk in the future.
So i think its a 4-channel amp running the mids and highs and another 2 amp channel running the underseat subs.
      03-20-2016, 09:49 AM   #13
lsturbointeg
what did you do for rear fills? stock?
      03-20-2016, 10:09 AM   #14
2tek
Daddy Wagon
Ireland
14
Drives: G31
Rear is a pair of Mosconi/Gladen speakers. The only thing that is still stock is the headunit.
      03-20-2016, 10:56 AM   #15
lsturbointeg
Nice! i'll have to see what they'll charge me for the rears as i don't see any rear kits listed here in the US unless the place you went to will ship Internationally?
      03-20-2016, 11:54 AM   #16
2tek
Daddy Wagon
Ireland
14
Drives: G31
Yeah give Germaniks a shout on facebook. I'm sure they can work out a shipping arrangement.
      03-21-2016, 10:09 PM   #17
Jcbama85
Jcbama85's Avatar
Drives: 2013 528i
Interesting topic, I'm upgrading my subs soon and would be interested to hear what happens if you get them
2013 528i Silver with Black interior "Tallulah"
Black Kidney Grills
Bavsound Stage 1 upgrade
BimmerTech Amp
      03-24-2016, 07:32 AM   #18
lsturbointeg
this might be an option for me since i decided i need my trunk space now
http://f10.m5post.com/forums/showthread.php?t=1238885
