2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N63 engine replacement question?
      04-30-2019, 09:10 AM   #89
550bye
550bye's Avatar
Drives: 2011 550i
2011 BMW 550i  [5.67]
Originally Posted by elmasry17 View Post
Originally Posted by Supahone View Post
This past winter I had the valve guides replaced under the class action at no cost on my 2011 550i with 92k. The oil consumption has not returned as I was losing a quart every 400 miles. I now change the oil every 5k miles using only full synthetic oil.
Hey there,
So you oil indicator stays full after 5k miles? I got my engine replaced and i still get oil consumption to add 1 quart of oil every 750miles. So your saying after valve guides replacement your not getting oil consumption even at 5kmiles?
Thanks
I can't speak for SUPAHONE but I can speak on my experience.
Before I got my valve stem seals replaced a little under a month ago, I could visually see be oil level drop on my dash, since then I have not seen it drop at all. When I first got my car back it stayed on that screen all day and every time I drove because I was so worried it would be the same result. I checked it using Carly (not sure how accurate that is but it seems legit) to see the exact percentage and I am at 98% after almost 1,500 miles.
Fingers crossed but only time will tell, I will have not hit the 5k mark but I am optimistic because the car feels much much better then it ever has. It definitely does not feel like a brand new motor but it is night and day compared to what it was.
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R.
      04-30-2019, 10:14 AM   #90
elmasry17
Drives: 2011 BMW x5 50!
Thats awesome buddy. Im happy for ya.
      04-30-2019, 10:38 AM   #91
Supahone
Supahone's Avatar
Drives: 11 550I, 07 335I,
Oil consumption
Correct, thus far since having the valve guides done I have not had to add a quart of oil within the 5k interval I have chosen to do an oil change. I've changed my oil once thus far and didnt have to add a quart of oil once having added 9 quarts during my last oil service.
      05-01-2019, 10:30 AM   #92
elmasry17
Wow thats amazing. So i guess ill take my car back to the dealer to check out the oil consumption and i still get smoke out of the exhaust while idling and stop and go traffic. The car is performing better and improved throttle response but its annoying to add 1 quart every 750miles and the smoke from exhaust is soo embarrassing. I cant believe after the engine replacement im still getting same issues.
Kyngofpop676.00
      05-06-2019, 07:38 PM   #93
Kyngofpop
Kyngofpop's Avatar
Drives: BMW 4
Embarrassing is an understatement. I wish you luck....I really do.
Janet Jackson Unbreakable World Tour
      05-21-2019, 09:28 AM   #94
elmasry17
UPDATE:
so took the car back again for oil consumption and smoke coming out from exhaust and keep in mind that i did tge engine replacement and still had issues. After some tests they decided to replace the valve stem seals and guides. They were surprised after i had the engine replacement that i still faced the same issues. Bmwna told the dealer to replace valve stem seals and guides. After the replacement they put new oil abd and told me to monitor the oil indicator. Just got the car back 4 days ago and put 650 miles and oil still full so i hope they solved the issue. Just last month i had to add 1 quart every 500 miles. So im keeping mynfigers crossed. The smoke coming out from exhaust while stop and go traffic and idling and decreased a bit now. So lets see how it goes.
Kyngofpop676.00
      06-04-2019, 12:28 PM   #95
thoreau1104@yahoo.com
Drives: 2014 BMW 550xi M Sport
Replaced engine in 2014, still having drivetrain malfunction issues
I had multiple drivetrain malfunction issues with my 2014 550xi msport, which resulted in replacing all of the HPFI, which didn't solve the issue. The dealer ultimately dropped in a new engine, and we're still having the hesitation issues on heavy acceleration. Took it in again with the new engine and they told me there was water in the gas (seems a cop out...).
Has anyone had this persistent issue? Any clue of the solution?
      06-05-2019, 07:22 AM   #96
DrSpaceMonkey
Drives: BMW 550i XDrive
Originally Posted by mtbrand View Post
If you have documentation of problems, expenses related to the lawsuit, go to your local BMW dealer, you may be able to prove you had problems prior to that 131k. Our dealer in Murrieta (CA) has had our car since 11/9/18. The lawsuit includes a rental car, so I've been driving a long-term rental since then...no cost to me.
Has any had a successful N63 replacement and happy with their experience in Southern California? If so, at what dealership and who was your service advisor? Thanks!
      06-05-2019, 10:09 AM   #97
kthankzbye
kthankzbye's Avatar
88
Drives: 2011 F10 550i, 2020 G05 40i
Anyone got the engine replacement in NY? I get low oil after 500 miles now. I only have 70000 miles on my car. Any good dealers?
      06-05-2019, 10:57 PM   #98
Boosted M5
Drives: F10 m5
Took mine in for oil consumption test and supposedly passed so basically I don't qualify for anything. What I did notice is that my oil interval is now 8k which tells me they reprogrammed it. Located in Northern California 2011 with 85k.
      07-14-2019, 07:20 AM   #99
BMW_Bob
Drives: 2011 BMW X5 Xdrive50i
Cool Engine Replacement
2011 X5 N63 replacement 110,121. $9,241.37 total
Labor is $3,300/Material is $5,927 (engine is $4,151)
BMW of NA would not waive the 121 miles over the 25% threshold. I had to pay 90%. Waited 9 weeks for engine. Took 7 days to install. Runs great so far. So why pay ~10K for a repair on a car you only paid 14K for???? Well the sticker was 84.6K in 2011 and all other aspects of the car are nearly showroom quality. So all the stuff that made it expensive then, makes it worth the funds now. Good luck to everyone with their own N63 story. (By the way...I have a 2012 X6 in evaluation program now also)
We must all remember, to own and drive the ultimate driving machine isn't cheap
      07-17-2019, 12:57 PM   #100
snlget
Drives: 2011 550i
quick question. I have a rebuilt salvage 2011 550i so BMW wont cover the engine replacement
was wondering if theres any other motors that can be swapped in instead for some cost savings?
      07-19-2019, 09:20 PM   #101
brogers710
brogers710's Avatar
Drives: 2008 BMW 328I & 2011 550i M-Sp
Replacement done
I got the engine replacement in late April and it took about a week to get engine done. I was in the 60/40 range so I owe around 6K, i opted for all hoses replaced too so it came closer to around $6800 for me. The car has been running great since. No more low oil lights, after 4K miles. I took to non-dealer recently and had all fluids replaced since it's a new engine and the owner on site made a comment that the engine looked like it was installed perfectly by experienced technician. Anyway the engine and the ride feels great now so I'm hoping that extra 6.8K gets me 200K more miles.
      08-19-2019, 09:40 PM   #102
Hanzo550
Hanzo550's Avatar
Drives: 2011 BMW 550i xdrive M Pkg
Originally Posted by beetle6986 View Post
My 2013 X5 has a new engine on order under the class action suit. I use a quart about every 700 miles. I complained about the issues when the car had less than 70k miles. They finally agreed it needed an engine once I passed the 80k mark by about 50 miles. Delaying action on their part certainly helped them as now I'm in the 45% bracket by about 50 miles. It failed both the oil consumption test and a compression test.
I have always had american cars my entire life except for one Nissan which had minimal problems. I'm amazed at the issues that come with a BMW.
I'm going thru the samething right now. I got my attorneys involved, and I'm gonna get the local news to give them some free publicity.
      09-20-2019, 12:59 AM   #103
ahcousa
Drives: 06 525i
Hi recently bought 09 x6 with n63, has 141k mi on it. It had cpo done in 2015 but still goes thru tons of oil. Called local dealer Century bmw of greenville sc and they said they cant help me since its over 130k mi. But if it had cpo done in 2015 shouldnt it be redone since repairs obviously failed? Any word?
      10-16-2019, 03:33 PM   #104
David3
Drives: E21 (x2), E46, F15, G05 LCI
Looks like my engine needs attention. 2 quarts burned in 1000 miles. Smokes after prolonged idling. 76,500 miles on 2012 N63. Cannot wait...not. Maybe I can get BMW to split the cost of the engine and I do the work...hmmm.
      11-06-2019, 08:45 PM   #105
MRod1787
Drives: 2006 BMW 325 2012 BMW 550I
I bought a 2012 BMW 550I with 70k miles Aug 2019 through private sale. Had a top of the line warranty still on it. Once warranty was transferred to me, I took it to the local BMW dealer. By then I had noticed the high oil consumption and some smoking. Luckily for me the previous owner had meticulous service records. They submitted the case to the warranty and BMW. Car had to stay at the shop as a third party inspector was sent by warranty. Got a call the following week and told BMW is replacing the engine. No cost to me. All in all it took 20 days to get my car back and they provided a loaner the entire time. Based on others specific cases I am happy. I am concerned though as I did not have to pay a percentage nor my warranty deductible. The invoice says replaced engine assembly, bled fluid, cleared adaptations. In the parts it has a lot of gaskets, exhaust manifold,exchange short engine, 2 installation kits, and lots of other parts. Does this sound like an engine replacement or just work done on the engine? Any help is appreciated. Thanks
      11-07-2019, 07:54 AM   #106
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
These are questions for your SA...You should of asked this before they even touched your car. How do you not know if BMW or your extended warranty paid? Seems like you do not ask ANY questions and go along with whatever the dealer does.
      11-07-2019, 08:43 AM   #107
MRod1787
Well OnlyGerman if you aren't going to help me with any answers then scoot on over for those who do want to help me. I asked as many questions as I could to my SA, and I got answers from him. What I am questioning is whether the job they SAID they did was done or not. Considering most on this thread had to pay some sort of percentage to get it fixed and I did not have to pay a dime. Which is why I am wondering if someone who knows about parts could give me their opinion. I wasnt going to fight it much once they told me engine would be replaced at 0 cost to me. So I dont care WHO paid it whether the warranty or BMW , I'm wondering what was done. Is that more clear ?
      11-07-2019, 08:56 AM   #108
Unspec
Unspec's Avatar
1312
Drives: 2015 BMW 535xi
Not sure why you would think they didn't do the work they claim to have done. It's a dealership, not some random shop on a back country road.
      11-07-2019, 09:16 AM   #109
MRod1787
I have trust issues as I've gotten burnt with a dealership in the past, not this one just another on a repair I had done, doesnt hurt to just ask does it?
      11-07-2019, 10:05 AM   #110
Unspec
Unspec's Avatar
1312
Take your car to an indy mechanic then, so he can see if you got the new parts or not.
