03-19-2020, 11:25 PM | #89 |
Rep 1,299
That kit is capable of 620whp... I bet you can get 550whp with pump gas on it. I am not going to waste money switching over unless I had a low mileage newer 2016/17 model. But looks like a good option if you going to pay 2500 on pure stage 2 then might as well on bb 3.3 as it comes with almost everything for FBO.
03-19-2020, 11:29 PM | #90 |
Rep 1,445
Drives: F10 S55, E93 M3, E89 N54
He said he could get the bb3.3 to spool just about as fast as the speed tech kit which, from what I have seen, has less lag than the PS2. But this is reading marketing materials, hard to say otherwise. Maybe I should ask him for some bb3.3 sample data files to see when boost is coming in hard and how many lbs it can run.
03-20-2020, 07:40 AM | #91 | |
Rep 1,230
Bmwdoubles_194.00 bigscore67.50 |
03-20-2020, 07:45 AM | #92 | |
Rep 1,230
03-20-2020, 11:07 AM | #93 | |
Rep 1,299
Are you running Helix OD? Last edited by ziekxq; 03-20-2020 at 12:06 PM.. |
03-20-2020, 05:20 PM | #94 |
Rep 1,299
Revision 2.5 logs:
1st run: https://datazap.me/u/ziekxq/v25-1st-...=0&data=4-5-22 2nd run: https://datazap.me/u/ziekxq/v25-2nd-...=0&data=4-5-22 3rd run: https://datazap.me/u/ziekxq/v25-3rd-...=0&data=4-5-22 Random logs: https://datazap.me/u/ziekxq/v25-rand...=0&data=4-5-22 https://datazap.me/u/ziekxq/v25-rand...=0&data=4-5-22 |
03-20-2020, 08:49 PM | #95 |
Rep 529
Rev 1.3 logs
Still a little laggy under 3k rpm. Check out the delta from boost target to actual. At 3k rpm only 10.8 PSI https://datazap.me/u/bmwdoubles/run-...#38;zoom=0-124 I will say the car fees stronger than it ever has. I'm sure the e50 is a contributor.
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
03-20-2020, 08:58 PM | #96 |
Rep 529
03-20-2020, 09:13 PM | #97 |
Rep 1,299
The boost falls off quickly with this new revision but same thing happen previously and he fixed it in last revision so hopefully he can help me hold the boost a little longer till 6200-6300k rpm.
03-20-2020, 09:18 PM | #98 |
Rep 1,445
Shouldn't you have more boost than that doubles with your HOD?
03-20-2020, 09:36 PM | #99 |
Rep 1,299
03-20-2020, 11:42 PM | #100 |
Rep 529
Yeah I have my 2.5 tmap right because the 3.5 was giving me errors. We should be able to pull out 20-22psi on the 2.p sensor and we'll go from there. I'm still early in my revision with DS. He's doing good work right now It's just been a bit slow with the back and forth. So in due time, I'm confident he'll have me running strong.
03-21-2020, 12:31 AM | #101 | |
Rep 1,299
03-21-2020, 10:39 AM | #102 |
Rep 1,230
will have to check the logs. im on spoolfx150 pump.
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
03-21-2020, 11:56 AM | #103 |
Rep 529
My man, aren't you going single turbo?
03-21-2020, 02:37 PM | #104 |
Rep 1,230
i have the speedtech kit just not installed yet. Was supposed to get the big boost but juan fucked me due to the motor mount issue for xdrive so im still on ps2 still have some room left to play with now that i fixed my issues and can boost more than 22psi. hoping to touch 600 before we make the swap
N55 GENERAL
Bmwdoubles_194.00 |
03-21-2020, 03:34 PM | #105 |
Rep 529
Here's my last run with D Shoup. It looks roughly like over 380 whp with these calculations.
442 ft-lb @ 5356Rpm Look at torque act.clutch nm https://datazap.me/u/bmwdoubles/run-...8;data=3-14-23 Then convert nm to torque https://www.metric-conversions.org/e...oot-pounds.htm Then calculate using rpm and torque https://spicerparts.com/calculators/...que-calculator Then multiply 15% drivetrain loss, take that number and minus it from the hp to get your real whp. Grant it these are very rough estimates without a dyno. It's ok with 17 PSI. Let's see if I can hit this 550whp mark. We're working on getting power down low since the manual and my hardware is laggy down there. I'm currently as a fast as a 550i stock or an e90 M3 stock in regard to numbers obviously a time slip will be the real truth or a lap time. Keep in mind I didn't rev this thing all the way out so I could actually be clearing 400whp. There's some hesitation at the top we're also working out so I'll wait to we have that cleared. I need to crush those 5.0's on track
03-21-2020, 08:41 PM | #106 |
Rep 529
Mr. Shoup coming through today!
Rev 1.5 at 19psi produces a smidge over 400whp https://datazap.me/u/bmwdoubles/run-...38;data=3-5-14 He mentioned 500whp is going to need more PSI. I'm guessing around 20whp per PSI so maybe 24-25psi to reach 500whp. We'll see.
03-21-2020, 08:50 PM | #107 | |
Rep 1,299
03-21-2020, 09:07 PM | #108 |
Rep 1,445
That's awesome. I thought that the PS2 with HOD would give you enough fuel to hit higher boost levels. I see you are 1 to 1.5 PSI off of target. Does he expect to be able to pull more PSI out of it?
03-21-2020, 09:19 PM | #109 |
Rep 529
Yeah we're anticipating 20psi
03-21-2020, 09:20 PM | #110 | ||
Rep 529
