2010 2011 BMW 5 Series Forum F10 A/C auto setting for fan |
04-25-2015, 01:53 PM | #1 |
Rep 6,862
Stupid question, but does anyone know how to have the auto setting control the fan speed as well? I hit the auto button but the fan speed never seems to change no matter how hot the car is.
04-25-2015, 07:11 PM | #2 | |
Rep 15,858
BTW, fan will still adjust even on the lower setting, according to need. HighlandPete |
04-26-2015, 07:54 AM | #3 |
Rep 6,862
Thanks Pete. Maybe I am misunderstanding, but wouldn't manually setting the fan intensity defeat the purpose of the auto program? For example, when I get in my car and it's 95 degrees I would expect the fan to automatically come on full blast and gradually decrease as the car cools.
04-26-2015, 08:10 AM | #4 | |
Rep 15,858
I personally run the lowest intensity and it still generates more air flow when needed, both for heating and cooling. I've tried higher intensity settings, just makes more airflow than I want or need. What bar is illuminated on the intensity/air volume display? Mine is set to the first bar, (lowest intensity setting). Set while in AUTO mode by using the fan buttons. HighlandPete |
04-26-2015, 08:53 AM | #5 |
Rep 6,862
The first bar is illuminated for me. I think what the issue maybe is that this system works differently than the one on my previous car (e90 m3). In my e90, simply selecting auto would have the car control the fan speed to the appropriate setting based on the temp inside the car. So during the hot south Florida summer when I first turned on the car it would be full blast with all of the bars illuminated. Then the bars/fan speed would gradually decrease automatically as the car cooled.
It sounds like in the f10 this maybe isn't possible? If I have to hit the fan speed button to increase/decrease the fan speed even while in auto mode doesn't that defeat the purpose of the auto mode? I know I am sounding redundant but I want to be sure I understand the auto function correctly. |
04-26-2015, 08:57 AM | #6 | |
Rep 29,202
04-26-2015, 10:31 AM | #7 | |
Rep 2,323
04-26-2015, 11:45 AM | #9 | |
Rep 15,858
The F10 system is an extension to, but easier to use than the E6x models, which had the intensity settings within the iDrive menu system. The fact it is on the display menu makes it so easy to set a preference, to how much airflow and fan speed range we want. As other users have indicated they use a higher intensity level than myself. I leave my intensity the same all year around, as I do the temperature. If I get in a hot car I simply hit the MAX button for the most effective cooling and knock it off as soon as it is near to comfort level. Even the lower intensity still gives quite a good range of airflow variation according to demand, just that it is never going to blast the cabin. HighlandPete |
ronjon40021.50 |
04-26-2015, 02:02 PM | #10 |
Rep 6,862
Maybe this is where I am getting confused. So if I select for example the 3rd bar of intensity, does this mean the fan will constantly stay at this speed until I lower the intensity? Or does this mean that the system will use this as an upper threshold not to exceed but will adjust itself to a slower speed if permitted (i.e. car is parked inside a cool garage thus a fan speed of the 3rd bar wouldnt be necessary to cool the car as it is already cool)?
04-26-2015, 02:25 PM | #11 |
Rep 5,091
It is slightly confusing and I was confused having come from a E39.
I have mine set to the 3rd bar and I think when we talk about intensity we are telling the system the maximum amount of airflow you want it to use. personal preference obviously but I find 3 bars suits me fine all year round. Coming from a E39 where the fan speed is set to auto, if getting into a hot car, the fan speed would go to max to cool the car as fast as possible. I was expecting the same behaviour in the F10 but this doesn't seem to be case if the intensity is set to say 1 bar. If you set it to 5 you may be aware that its quite noisy. best thing is to experiment and see what you find suits you. For me I leave everything in auto, temperature to 22 in winter and perhaps a bit lower in summer down to 19 and the intensity to 3 bars. You can also adjust the middle vent from red to blue to fine tune the temperature of the face vents separate from the other vents in the car. |
04-26-2015, 02:35 PM | #12 |
Rep 1,597
Think of it like a secondary adjustment on the auto function.
In the older versions of the system you selected auto and the ventilation system controlled the airflow and temperature for you, however this was a generic setting with no fine tuning available. The F10 system does the same job however the fan speed adjustment allows you select how aggressively you want to apply the airflow proportion of the function. Therefore selecting one bar will still vary the fan speed but at a moderate rate, selecting five bars will also adjust the fan speed but at the maximun most aggressive rate. I generally use three or four bars and use the max cooling function on hot days to bring the cabin temperature to a comfortable level before switching back to auto.
Current: VW Transporter Sportline, F48 X1 20i M Sport. Previous: F10 530d M Sport, W176 A200 CDI AMG Evolution, E70 X5 3.0 SD M Sport, F20 120d M Sport, E81 120d M Sport, E46 325i M Sport, E46 318ci & Many Others...
04-26-2015, 03:50 PM | #13 |
Rep 29,202
This.
04-27-2015, 08:30 AM | #14 | |
Rep 2,323
04-28-2015, 07:24 PM | #15 |
flyboy
9
Rep 10
Drives: 2011 550ix
A good point was raised here and no one has definitively answered the question. Does AUTO really mean AUTO to the extent that fan speeds are AUTOMATICALLY adjusted depending on how fast the car is either cooling down or heating up.
04-29-2015, 02:45 AM | #16 | |
Rep 15,858
Mine certainly does in full auto mode, according to heating or cooling demand. Listen carefully and you will notice the changes. I think many of us are used to the older systems where the fan would quite often go to maximum speeds as the norm and gradually cut back. HighlandPete |
04-29-2015, 03:55 AM | #17 | |
Rep 1,597
I think that it is more apparent on a hot day when your calling for cool air as the A/C can kick in immediately to cool the cabin. On cold days when your calling for warm air the engine has to heat before the system will start to raise the fan speed.
04-30-2015, 06:40 AM | #18 |
Rep 6,862
Based on playing around with the settings over the past few days I think this is correct. Second bar seems to be the sweet spot for me as the third bar never seems to be calm enough even after the car was already cool.
05-01-2015, 06:54 PM | #19 |
vroom vroom
19
Rep 134
06-22-2017, 08:41 AM | #20 |
Rep 1
Problem?
Question for the experts. I'm not sure if I need to bring my 2014 535xi in for service. When in Auto, the fan speed will not change once the initial cabin temp has been achieved.
Specifically, I can change the internal temp setting from 75 degrees to as low as 60 degrees and the fan speed does not change. I've even adjusted the max auto speed setting to 5 and have not noticed a change. In all of my other cars, the fan speeds automatically adjust if the car is getting too hot/cold, sun, temp adjustment, etc. Am I missing something, or is my unit faulty? Much appreciated! |
06-22-2017, 05:49 PM | #21 | |
Rep 15,858
I've found if you only change by a degree or two, there may be little fan speed change in auto mode. The wider the temperature change dialled in, the greater the fan speed response, automatically adjusts to higher speed. This applies both to cooling and to heating. Last edited by HighlandPete; 06-22-2017 at 05:54 PM.. |
08-02-2021, 07:28 AM | #22 |
Rep 210
I have a question about the auto a/c and rather than make a new thread...necrobump!
In my car, when I have the a/c set to full auto, max intensity (5 bars), the temp set to 70, and it's in the mid-90's outside...when I start my car it takes quite a while for the fan speed to pick up. I'm sitting in the hot car and the system slowly increases fan speed over what seems like minutes. If I want to cool off quickly I just hit max cool. Even if I drop the temp down to 60, it still is slow to increase fan speed. So, is this typical? How does your climate control system react to this scenario (auto, big temp differential, max intensity)? |
