2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Made a custom exhaust and x-pipe
      09-05-2011, 05:39 PM   #1
Edman951
Edman951's Avatar
Drives: 2014 i3, Capparis White
Decided to try making my own x-pipe and exhaust.
I wanted a modular system that i could use only the x-pipe with the factory exhaust, and with my exhaust. and be able to put everything back to stock easily.
I used the factory bolted clamps to make it a bolt on and off system.
I couldn't find a x-pipe that was 2-3/4'' OD, so i looked around and found a x-pipe made for a C6 Corvette that was very close to what i needed, but was 2-1/2''OD. So not the best for flow, but figured it would do the job for now.
On thing to note is the car runs 9psi stock., and when i did a test drive using just the x-pipe, i was seeing about 12psi on my gauges, so this car really likes less restriction. and when i drove it with the factory exhaust connected, boost went back to 9psi. I was thinking to redo it with 3'' pipe maybe someday.
Here are a few pics.
I cut the factory exhaust after the secondary cats, and before the muffler cross brace. I can install my x-pipe with the factory mufflers, or with my home made mufflers. so my system is modular by using BMW bolted clamps, and fast to go from one setup to the other, and back to stock.
I used Vibrant stainless steel piping, and two of there resonators as mufflers.
Making it a very cost effective system.
Sure my weld are not sexy, but all in all, i'm happy i did it, was a fun small project, and didn't cost me much.
It's not a high dollars engineered system, but still sound pretty good.
It does have the typical drone as do most exhaust systems.
Current, i3 Capparis White, Lodge interior
Ex- F10 550i Xdrive M sport, white
Ex- trade-in 2008 E90 M3
mpbmw9438.00
STR8-6IX536.00
      09-05-2011, 05:41 PM   #2
Edman951
Edman951's Avatar
      09-05-2011, 06:07 PM   #3
DSB_550
Drives: 11' 550i
sounds great! The stock exhaust is really the only thing i dislike about the car. I understand why most people would want a 5 series to be quiet...i'm just not most people
I was thinking about having a custom exhaust done instead of spending the ridiculous $$$$ on an overpriced system.
      09-05-2011, 06:10 PM   #4
Drives: 991TTs
for some reason i was expecting it to be much louder but it sounds great, nice car!
do you plan to put downpipes?
      09-05-2011, 07:09 PM   #5
tp550i
tp550i's Avatar
Drives: 2011 550i Sport
I agree. What mufflers did you end up using?
F10 550i Space Gray | Dinan Stage 5 | Eisenmann Race | ACS springs | 20" Ferric Grey 312 - Michelin PSS
      09-05-2011, 07:23 PM   #6
alextremo
Drives: F10 550i
Sounds/looks great - nice work!
Can you give us some details on your gauge set up?
      09-05-2011, 08:12 PM   #7
Edman951
Edman951's Avatar
Thanks Guys.
No its not that load at all, very suddle actually
I used some vibrant ultra quiet resonators.
http://vibrantperformance.com/catalo...1022_1033_1055
as i wanted the shortest muffler i could find in a straight thru design.
-no plan for a downpipe for me at this point.
      09-05-2011, 08:15 PM   #8
Edman951
Edman951's Avatar
I'll take some pictures tomorrow and post how i made it work. Since our cars don't have boost lines to tap off too. But I found a solution.
      09-05-2011, 09:05 PM   #9
gray550
gray550's Avatar
10
Drives: M4 Comp, M3CS, Corvette C8
Just curious as to why you didn't remove the secondary cats?
      09-05-2011, 11:23 PM   #10
Edman951
Edman951's Avatar
No plan to bypass the secondary cats yet, it may get to raspy.
but it may bring in more spooling sound.
makes me go hmmm!!!
      09-06-2011, 12:11 AM   #11
Woobros2win
Drives: 535 x drive M sport
Edman951, did you lower your spring too. Also what are
Spec for your rear tires. They seem to be wider than mine.
I also have x drive and my rear tire spec are 245/40/19
which I dont like. By the way nice sound.
      09-06-2011, 12:48 AM   #12
blankstar43
Drives: 2012 e92 M3
good sounding exhaust. I'd really like to hear it with the secondary cats deleted now
2012 JZB/Fox Red M3 DCT -JZB reflectors, CF gills, gloss black grills
      09-06-2011, 01:43 AM   #13
gray550
gray550's Avatar
10
makes me go hmmm!!!
My plan is remove secondary cats but keep the resonator - the opposite of your setup. Not sure how it will sound! I'm thinking the secondary cats will have more restriction than the resonator so by removing them it should free up the flow. Only way to know is to try it - right?
      09-06-2011, 02:11 AM   #14
78mao
78mao's Avatar
Taiwan
132
2015 M3 BMW M3  [1.00]
very nice! vibrant makes really nice mufflers!
      09-06-2011, 04:07 PM   #15
EBRSKIH
Chef
17
Drives: F10 550i
Sounds real good..I need an exhaust asap
2013 X6 50i Sapphire Black
2012 550x Alpine White
- 12.727@108 - 1.7 60ft lemon'd
2011 550i Sapphire Black
- 12.960@109 - lemon'd
      09-06-2011, 05:11 PM   #16
Edman951
Edman951's Avatar
The secondary cats are not restrictive from what i saw.
here's a picture i took.
      09-06-2011, 08:05 PM   #17
Edman951
Edman951's Avatar
Stock wheel, tires and springs for now.
I have a set of H&R, but haven't had the time to get them installed.
      09-06-2011, 09:32 PM   #18
TheStig
TheStig's Avatar
Drives: Alot of everything.
Sounds Great! Beautiful Car bro!
Gone But Not forgotten:
-07 Shelby GT500 W/ Full Bolt on E85
-08 335i 6MT W/ Full Bolt On E85/Meth
-08 M3 DCT W/ Full Exhaust / Tune
-13 B8 Audi S4 APR Stage 2+
      09-09-2011, 01:55 PM   #19
EBRSKIH
Chef
17
Drives: F10 550i
Was the exhaust note increased noticeably with just the Xpipe from the C6 with the OEM mufflers? Also do you have any idea on how to get the exhaust flaps to stay open always? Thanks
      09-09-2011, 09:20 PM   #20
tp550i
tp550i's Avatar
good question. removing the resonator and adding an x-pipe looks like an easy solution. there's a few aftermarket x-pipes available as well.
      09-12-2011, 02:08 PM   #21
EBRSKIH
Chef
17
Drives: F10 550i
Are you talking about supersprint? Edman can you reply please im really interested
      09-12-2011, 07:34 PM   #22
blankstar43
Drives: 2012 e92 M3
where can these xpipes be purchased at?
