10-02-2013, 06:35 PM | #1 |
Rep 21
Connect drive
Hi need some help with the following for my 2014 535
- cannot get my bmw apps to work - cannot get my email or text - cannot connect the phone via USB
Current :535xi
Turned in :2011X5 5.0 |
10-02-2013, 09:35 PM | #2 |
Rep 553
BMW Apps seem not to work for most of us. You are not alone.
For the phone, if you have an iPhone, try these steps. http://f10.5post.com/forums/showthread.php?t=882491 If you connect via USB, you may loose Bluetooth audio (but not telephone)...in some phones it's one or the other for music. For example, in iPhone, if you have the iPhone connected to the car by USB, it won't also play music through the earpiece port or possibly also through Bluetooth.
Regards,
MWPos |
10-02-2013, 10:22 PM | #3 | |
Rep 21
Still cannot get software to update
Current :535xi
10-02-2013, 10:26 PM | #4 |
Rep 21
I can see the USB and the software is loaded to it , however it just will not take the update
Current :535xi
10-02-2013, 10:26 PM | #5 |
Rep 553
Hmmm...Do you have the USB data stick formatted as FAT32 with default cluster size, with the UPDXXXX.BIN file as the only file?
Regards,
MWPos |
10-02-2013, 10:29 PM | #6 |
Rep 21
Not sure whats it formatted to , but I have other stuff on it , even music that I access from the iDrive
Current :535xi
10-02-2013, 10:47 PM | #7 |
Rep 553
Let's make it REALLY SIMPLE for the car (and our troubleshooting )
First, download the update file again in case it was corrupted on the first attempt. 1) connect the data stick to your computer and copy everything off of it that you want to ever see again. 2) right-click on the data drive in Computer, and from the pop-up menu, select Format. 3) From Format, select FAT32 and Default Cluster Size (Quick Format is OK for this) 4) When complete, copy only the UPDXXXXX.BIN file to the data drive. 5) view the contents of the data drive. The .BIN file should be the only file on the drive. 6) insert the drive into the armrest USB port and try the update again. If that doesn't work...I'll try to come up with something!
Regards,
MWPos |
10-03-2013, 09:37 AM | #8 | |
Rep 21
10-06-2013, 11:51 AM | #9 |
Rep 1
I will hijack this thread slightly. I've just bought a two year old 520d (F10) which apparently has Connected drive/BMW Online. What I want to know is this - what does this even do? Apparently it's not supported in our country so our local BMW site doesn't say much. From what I understand it's supposed to offer access to email and some other online services.
And of course since BMW doesn't officially support this thing in our country - is it even possible to get it working here? Right now it just says that I need an account/contract so that's pretty much all that I know about this. Do you need to pay anything for this to work? |
10-07-2013, 11:17 AM | #11 |
Rep 21
So since my post
- I am now able to get my text messages , still no email - I will get the USB cable to work if I play with it for a bit ( tried different cables same result ) not worried too much until my new iPhone 5s arrive this week - BMW apps says its connected by will not launch - still unable to update software via USB drive |
