2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 11 550 xdrive loud as hell
      12-09-2023, 12:45 PM   #1
headache876
Drives: F10 550xi
This car is a Copart build. So to this point Arm front facing, arm charge pipes, vrsf cat less down pipes, 2x turbo smart diverter valves, and the Megan supremo exhaust to try and quiet it down. But cold start wakes the dead, and if I want to get frisky wot it just screams. It does have the resonators past the down pipes but it’s unclear if they’ve been gutted and I see weld marks like they may have been changed or whatever. Any ideas
      12-09-2023, 02:47 PM   #2
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
Just install quieter exhaust parts
If you install louder exhaust parts, the car is going to be louder, I thought this much was obvious.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      12-09-2023, 03:53 PM   #3
headache876
Drives: F10 550xi
I added the mufflers it brought it down some but as you build up to WOT it has this nasty rasp. Only thing left would be to replace the middle set of resonators to bring the sound level down
      12-09-2023, 07:03 PM   #4
Unspec
Unspec's Avatar
1301
Then it sounds like you know what to do.
Or install the OEM mufflers.
2015 BMW 535xi
      12-10-2023, 09:01 AM   #5
itsnota2ma
itsnota2ma's Avatar
20
Drives: 2012 550i xDrive Msport
I am curious, what brand are the smart diverter valves?? I found ones out of Australia, but they don't fit the N63, only the S63.
      12-11-2023, 02:23 AM   #6
headache876
Drives: F10 550xi
They are turbo smart. But I’ll be honest, I don’t hear a damn thing from them.
      12-11-2023, 09:22 PM   #7
Unspec
Unspec's Avatar
1301
If they're plumbback, you're not supposed to. If you do, something's broken.
That said, the one that people use for N63's fit, but Turbosmart also specifically states on their website they're not for N63/S63 applications, and instead are for N55's
2015 BMW 535xi
      12-12-2023, 01:13 AM   #8
Aussie_550i
Australia
12
Drives: 2011 550i, 2017 430i
I use them on my n63 and haave so far had 2 fail as the soleniods haave failed. The interesting part about the failures is its the same bank.
      12-12-2023, 12:34 PM   #9
headache876
Drives: F10 550xi
Found one issue, no boost. Seems my car has a monster leak somewhere, and during a logging session its creating little to no boost at all. So, got to solve that problem now..
