2010 2011 BMW 5 Series Forum F10 Guys On The Forum With BMS For 550i |
12-17-2013, 02:29 PM | #1 |
Rep 26
I just wanted to ask three questions:
1. Do you hear the Turbo more with the Tune? 2. Do you feel a difference or just know its there? 3. Did it affect your gas mileage? I am expecting worse than stock... Last edited by nosonyx550; 12-17-2013 at 02:32 PM.. Reason: Spacing out the topic |
12-17-2013, 03:05 PM | #2 | |
Rep 1,250
Drives: 20' X3M CP
2. not really a difference. 3. No. Same.
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 | |
12-17-2013, 08:05 PM | #3 |
Rep 2,080
12-17-2013, 08:42 PM | #4 |
Rep 82
I've just put the tune back today after not having it in for the past two weeks.
1. I couldn't really tell a difference in the amount of turbo spool with and without the tune installed 2. You can definitely feel a little more power in the lower RPMs but at the higher RPMs you can definitely feel the power from the extra boost. 3. I haven't noticed any difference in gas mileage |
12-19-2013, 07:17 PM | #6 | |
Rep 165
2. Definitely, 100%. You will know its there the instant you start to drive the car after the install of the bms tune. Actually, because Terry had to swap out my harness cable, I could really feel the difference the tune made when I uninstalled it and had to drive the car without the tune. Felt like a far less powerful car. On that note, after driving with this tune installed for several months and with no problems, I have become used to the power and increased throttle response and feel like this is the baseline normal for the vehicle. But sadly to say, the wow factor has somewhat diminished for me. 3. I have not seen any appreciable change in gas mileage. I would say that it's been the same before and after the bms stage 1 tune. |
12-25-2013, 09:18 AM | #7 |
Rep 2,080
Stage 2 is on its way. Fear not. Well at least for us 2011-2013 550 guys. There is no plan to support 2014+ with the newer n63tu as it had a different ecu setup. Glad I didn't switch to a 2014.
12-25-2013, 09:28 PM | #8 |
Rep 2,416
haha right i was like fuck! should of got 2014.. then terry is like Stage 2 for 2013 only .. THANK GOD I GOT THE 2013
2011 550i RWD 60-130 7.35
12-25-2013, 10:52 PM | #9 | |
Rep 1,250
Drives: 20' X3M CP
Stage one is a 20-25 hp gain. Stage 2 better be over 50. Then just maybe you will have the hp that the N63tu motor has stock. Then again stage 1 works for 14s |
12-25-2013, 11:19 PM | #10 |
Rep 2,416
are you serious right now ? i make way more than N63 TU with my stage 1 BMS
12-25-2013, 11:23 PM | #11 |
Rep 1,250
Drives: 20' X3M CP
12-26-2013, 12:05 AM | #13 |
Rep 2,416
Stage 2 will not work with 2014 and only will work with 2011-2013 cars
12-26-2013, 12:07 AM | #14 |
Rep 2,416
45 crank HP is not 45 wheel hp... my 550xi pushes 421.5 WHP/ 467.9 WTQ on stang dyno... if you are going to strap it on any other dyno add another 20% and if you want to measure crank power i am well over 500HP and probly 550TQ
12-26-2013, 12:24 AM | #16 | |
Rep 1,250
Drives: 20' X3M CP
With your all wheel drive set up. 20-25 percent loss. Vs just rwd cars 15-20% But I think your taking my msgs in the wrong way. I am very jealous that you 11-13 boys get the stage 2. But the reason I'm even taking the time to write this stuff Is because you and Scott were saying how you lucky You didn't get the 14 etc when 14s stock make the same power at the wheels That a stage 2 2013 will. |
12-26-2013, 01:06 AM | #17 | |
Rep 2,416
12-26-2013, 01:41 AM | #18 |
Rep 1,250
Drives: 20' X3M CP
2013 starts with 400hp
2014 starts with 445hp Stage one Adds 35 hp to the wheels. According to Terrys dyno on the 2011. Bmw under rates all their cars. For example the 2011 f10 Terry dynod stock at 392 to the wheels. After stage 1 It went up to 425. 2014s stock will dyno at 435-440 to the wheels. Same concept. Under rated. So again. A stage 1 2014 will make more power than a stage 2 2013. A 2013 stage 1 doesn't make more power than a stock 2014 Further more. I'll be doing a ecutuning group tune and I will dyno. Like I told u before. So we'll see what that yields. But I would of rather had a stage 2 bms but That isn't an option at the moment. |
12-26-2013, 01:45 AM | #19 |
Rep 1,250
Drives: 20' X3M CP
That's the reason your car dynod so high with stage one. Because BMW under rates it's factory hp.
How else do u think you made so much power with just a stage 1? 20% loss - 400hp engine to wheels is 80hp. So 320. U made 420+ with stage 1. Do u think u gained 100++ hp on a Mustang dyno just from a burger stage 1? Come on bro. |
12-27-2013, 01:33 PM | #20 | |
Rep 2,416
Both done on same day same Dyno with in minutes of each other. ___________________ Stock Numbers: 354.9 / 394 BMS stage 1 + 4 PSI: 421.5/ 467.9 67WHP and 74WTQ increase
12-27-2013, 04:09 PM | #21 | |
Rep 1,250
Drives: 20' X3M CP
Nice. I never saw your dyno. Just your signature hp/tq numbers.
I wonder what it would make just with stage 1 and reg 93 or 91 octane. Quote:
