2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N63 Alpina Turbos Installed
      03-10-2018, 12:55 PM   #45
Morebs4me
Drives: 550i
Originally Posted by MattPro View Post
I definitely agree. Sadly I have to do emissions within 8 months, but after I plan to get some downpipes. And currently I have the stock mufflers removed, so it should be pretty damn free flowing after I get the DPs.
I've also been silently hoping we get a flash option for the DPs but I know that's never going to happen
Who has alpinas installed? Someone’s who’s done it, message me.
      03-10-2018, 05:29 PM   #46
addy27
Drives: F10 550i
Also, question about the Diverter vs Blow Off valve. Are they interchangeable as would a N63TU Turbo become backwards compatible by switching the Blow-off valve with the Diverter valve?
And what about the opposite, Any benefits to switching to the N63TU BlowOff valve?
      03-13-2018, 01:08 AM   #47
Morebs4me
Drives: 550i
Is Matt and flyboy okay? I need help with my alpina setup lol. Flyboy has posts with my same problems I have and didn’t mention how he resolved it that I could find.
      04-04-2018, 01:39 PM   #48
addy27
Drives: F10 550i
Wondering if you guys replaced the oil return pipes with new ones or used existing when you put the Alpina turbos on.
      04-07-2018, 02:15 PM   #49
Morebs4me
Drives: 550i
I used the same one. My issues were all related to a bad diverter valve.
      07-27-2018, 01:28 AM   #50
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
Finally got around to installing my rebuilt Alpina turbos this weekend. Just wanted to share the experience in case anyone else decides to go this route.
I bought the turbos for $500 from an E30 forum, in "working when pulled" condition from someone at a dealership. After receiving the turbos, I noticed that one had very bad axial shaft play (I measured .005"). I contacted 5 companies that rebuilt turbos and only one was up to the task, Pure turbos. I paid a little over $1000 for the rebuild. I was very happy with their work besides the fact they forgot to mail them back to me on time, and then 2-3 weeks later when I emailed asking the status they never responded and just put them in the mail.
My parts list from BMW for the install:
(sorry, lost the description for what they are, but they are all the crush washers/gaskets you would need)
07119963201 x8
11428624158 x2
07119963072 x4
11657577018 x2
11627576991 x2
After receiving:
View post on imgur.com
I started the install at 12:30 in a friend's garage. Airboxes removed:
Stock turbos with heat shields removed:
Stock intake:
Turbos removed:
Surprisingly, my old turbos with 63k on the clock had extremely minimal shaft play. I'm impressed.
Old vs new:
Visually, they're exactly the same from the housings. If you look at the compressor wheel you can see they have an obviously different design.
New turbos installed:
Cranked the car in small intervals without starting to prime the turbos then fired her up. Ran perfect from the start and no issues.
After a test drive...I'm moderately disappointed. I can feel an improvement on the low end, in comfort mode the torque is hitting a lot earlier than I normally would expect it to. On the high end...I don't feel much of a change. I'm on the basic BMS S2 settings still, and have stock downpipes, so I feel like if I turn up the boost/aggressiveness I would notice it more. I do think these would make a huge difference on a TU where a flash tune would be possible. Also, it's worth noting that I was planning on installing an intake so I left the airboxes open essentially as a hot air intake. With the intakes installed I may notice a much bigger difference.
Overall, the install wasn't that difficult, but a lot of the time is spent cursing and trying to access the bottom v-bands and oil drain lines. I was able to finish in about 5-6 hours.
If you're thinking about going this route and have any questions let me know!
How difficult was it to remove the alternator?
      03-06-2024, 04:47 PM   #51
headache876
Drives: F10 550xi
Bump for an old thread. Did you have to move the alternator to get the turbos installed? On my passenger side. I can’t get the turbo in with the waste gate and diverter valve installed, there just isn’t enough room unless I move the alternator back some
      03-08-2024, 01:58 AM   #52
Hornet-01
Hornet-01's Avatar
Russia
122
Drives: BMW 550 xdrive
2011 550ix  [9.50]
with turbines from XME the result is more interesting, but you are faced with the problem of tuning the twin-scroll exhaust manifold
      03-08-2024, 11:12 PM   #53
addy27
Drives: F10 550i
Dont recall having to remove the alternator..
Hornet-01121.50
      03-10-2024, 06:37 PM   #54
headache876
Drives: F10 550xi
I finally got them installed but now I had to order the clamp that goes from turbo to manifold and a new turbosmart solenoid as it broke on installation.
