2010 2011 BMW 5 Series Forum F10 Will this set up fit my non m-sport |
09-06-2017, 04:49 PM | #1 |
Rep 82
Looking to get the following wheel setup for my f10 non sport... will everything fit properly with these measurements ?
5x120 19x9.5 + 35 (square setup) Hankook ventus front 255/35 rear 275/35 |
09-06-2017, 06:34 PM | #2 | |
Rep 29
Front: 245 Rear: 285 You can find threads here that have spoken about this subject if you want to clarify. |
09-06-2017, 06:47 PM | #3 |
Rep 82
I have the i not the 4 wheel I did some browsing through the threads and to the best of my knowledge the 35mm offset will work depending on the tire and I think the described tires inhave should provide the clearances I need but please correct me if I'm wrong I don't want to purchase these wheels and have them not fit
09-06-2017, 08:17 PM | #4 | |
Rep 77
09-07-2017, 07:57 AM | #5 |
Rep 82
https://tiresize.com/wheel-offset-calculator/
Check it this calculator for wheels do you think it's reasonable? |
09-07-2017, 03:33 PM | #6 | |
Rep 29
All your rims are the same width, that does not make it a square set up if there are staggered tires on those rims. If you want to go with 255 up front, go with 285 in the rear. Or factory: Front - 245 Rear - 275 |
09-08-2017, 08:40 PM | #7 |
Rep 82
I started playing around with tire sizes I want to use 245/35/19 up front with the 9.5 rim and 255/35/19 9.5 rim on the rear with the 35mm offset I should be clear of rubbing ?
09-09-2017, 03:08 AM | #8 |
Rep 29,202
Why the 35 profile tires? :
