2010 2011 BMW 5 Series Forum F10 Simple trip to BMW Dealer.... |
05-03-2019, 08:55 PM | #1 |
Rep 1,254
2013 550i
Simple trip to BMW Dealer to get oil change 46k miles Surprise surprise I need upper oil pan gasket and lower pan gasket they told me its leaking. I never notice any leaks in my garage I always park in same spot, They also mentioned I need coolant flush and Differential fluid changed. I do have warranty they have to call and ask if they will cover gaskets. My issue is 46k miles its FU(king leaking and what's the deal Coolant flush at 46k miles and differential flush IMO its soon that should be more like 75k miles.
05-03-2019, 10:29 PM | #2 |
Rep 161
Drives: 2014 535ix
Oil pan gaskets on all BMWs have been a problem for decades. I've owned 6 BMWs and did coolant flushes every two years on all of them -- cheap insurance. Front differential failed on my E91 out of warranty at 52k mi so I should have flushed it and transfer case. Also ZF factory recommends a transmission flush at 60k.
2014 535i XDrive Alpine/Mocha Nappa Contour
EL Jeffe 5611.50 |
05-03-2019, 10:41 PM | #3 | |
Rep 5,366
05-03-2019, 10:44 PM | #4 | ||
Rep 1,254
It's not like oil goes bad after time
05-03-2019, 11:28 PM | #6 |
Rep 14,521
how about the oil filter housing gasket?
05-04-2019, 09:06 AM | #7 |
Rep 342
Shit design and material properties. Component parts are all driven by cost reductions now so while they could use a better engineering grade of rubber for the gaskets that would last the life of the car, they use the cheapest material that will work to get it past 5 yrs or so (warranty period)... sometimes just to save a few cents (which adds up when your buying hundreds of thousands of them....) I work in Procurement Engineering; that is part of what we do. Also it is not aerospace or medical where if a gasket starts leaking someone might die, so the risk factor is low for BMW. Sometimes an aftermarket part might be a better choice. |
05-04-2019, 09:39 AM | #8 | |
Rep 14,521
05-04-2019, 10:16 AM | #9 |
Rep 1,126
BMW should fire retard employees and board members and invest more money in better materials. My proposal can help BMW achieve better reliability. 🤣 I can personally guarantee it.
05-04-2019, 02:18 PM | #10 |
Rep 247
I've owned 5 BMWs over the years and every single one of them has leaked oil at one or more times. That said, they've also all felt great to drive even as they got into higher mileage. It seems like the driving experience (and general appearance) holds up well, but gaskets, seals, etc. need more frequent maintenance attention than I would prefer. Overall, it's an OK tradeoff for me, although obviously would be better if they could figure out how to prevent such early failure on the gaskets.
05-04-2019, 06:34 PM | #11 |
Rep 1,214
Upper and lower oil pan gasket leaks are common to the N63, but not at your mileage.
I would have it reinspected by an independant you trust. I have a ton of clients come to me from dealerships seeking second opinions and I find the overwhelming majority of dealer found LEAKS are an insignificant seep or weep and have 10's of thousands of miles and or years to go before they start dripping. That said the fiberous engine undertray catches leaks for awhile before owners notice them, and I've had a number of clients willing to throw hands with me when I tell them there car has a leak until I walk them out with the diaper off the car and they can see for themselves.... Dripping = Leak where I am concerned. Weep and seep are only enough oil moisture to accumulate dust sticking to them. Differential fluid should be serviced in the 80-100k range. BMW's official stance on coolant now is that it is a lifetime fluid, warranty only pays for it to be exchanged as part of a covered repair. Otherwise coolant should be exchanged every 4 years to ensure it maintains its pH balance and lubricating properties. |
05-05-2019, 05:20 AM | #12 |
Rep 37
Don't feel bad I have a 2016 550 Msport that has 38,300 miles and they are pulling the engine out to replace the valve guide seals, reassembling the cylinder heads, replacing leaking lower timing case cover gaskets, replacing the crankshaft seal.....the dealer I have it at has 6 service bays with engines pulled out with the same problem. This is my 3rd 550. Fortunately for me, it is a lease and I return the vehicle right after the job is complete. To this day, I would never own the N63Tu outright or without a wicked warranty. I have spent the last 30 days driving a 2 series, I am 6'3 not fun.
Once its returned next month, it will be auctioned as its not worth shit. 38,300 miles. Time to step away form BMW...... Like BB king said, "the thrill is gone" |
05-05-2019, 08:03 AM | #13 | |
Rep 1,254
For me I still don't know how will this shakeout Service advisor still didn't call me back To tell me if warranty will cover repair. If they don't approve repair it I will have to do some hard thinking as I did when I had Audi A8L With endless repairs.
05-05-2019, 08:10 AM | #14 | |
Rep 1,254
I never notice anything under my car. Last time I drove 8k miles only had to add 1qt of oil. I was told by service advisory that's almost unheard of on this engine. I might be just Exaggerating and freaking out I need liftup my car and check this with my own eyes. They might be just trying to get paid from warranty company.
05-06-2019, 07:50 PM | #16 |
Rep 1,254
I don't know I still didn't get a chance to clim under the car to see this for my self
Like I said earlier I never notice any leaks @Stück mentioned earlier you can go sometimes miles and miles before you get real leak and dripping. at this point not sure what to do if I should press warranty company to pay for work or just say fuck it
05-06-2019, 07:52 PM | #17 |
Rep 1,214
N63's don't have an oil filter housing gasket... the oil filter housing is the upper oil pan....
EL Jeffe 5611.50 |
05-06-2019, 07:55 PM | #18 | |
Rep 1,254
so what you saying Diff fluid don't worry until at leas 80k Coolant flush I should but does is matter I do not drive my car in winter?
05-06-2019, 08:03 PM | #19 |
Rep 1,214
Unless they can show you the coolant is contaminated, or the pH is out of spec I would file the recommendation under "wallet flush" which dealers have a wide menu of.
4 years is a solid recommendation, but in most cases these cars don't hold the same coolant in for 4 years anyway. Either a failed component or unrelated service that opens the cooling system will provide fresh coolant infusion at some point more often than not... |
05-06-2019, 08:06 PM | #20 | |
Rep 1,254
I would think they did coolant at that point wouldn't you think I think they just trying to Fuck me
05-06-2019, 09:03 PM | #21 |
Rep 161
Drives: 2014 535ix
For coolant, I go with Mike Miller's maintenance schedule:
"The factory coolant change interval used to be every two years. Starting in the late 1990s, BMW lengthened the coolant change interval to every three years, then every four years. As of 2004, BMW says coolant is “lifetime fill.” There was no discernable change in original BMW anti-freeze during this transition, other than who pays for the service during the warranty period. I recommend changing engine coolant at two-year intervals, using only factory BMW anti-freeze mixed 50-50 with distilled water (reason – BMW anti-freeze is phosphate free, phosphates cause aluminum oxidation, which blocks cylinder head coolant passages and causes head gasket failure, others may claim to be “aluminum safe” or “phosphate free” – make your choice, but I’ve used BMW anti-freeze exclusively in many cars and have never had an aluminum oxidation or head gasket problem)."
EL Jeffe 5611.50 |
