02-26-2020, 07:45 AM | #1 |
Rep 1,254
Will it stick out
Simple question Currently in process of getting new tires
as of now rear 285 30 20R on 10.5 wheel with et40 I like to go 305 30 20R Will the tire stick out? Thanks
02-26-2020, 08:39 AM | #2 | |
Rep 7,487
The site above will give you the "poke" (how much the tires will stick out toward the fender) and "inset" (how close the combo will be toward the suspension parts). You can take the data and measure if the new set-up will poke out past your fenders.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
02-26-2020, 04:51 PM | #3 | ||
Rep 1,254
It still doesn't tell me if tire will pass the rear quarter panel Is anyone here running 305s
02-26-2020, 05:08 PM | #4 |
Rep 716
I think it will stick out... I have 295/30/20 on 20x10 et40
philipm78581.00 concept3287.50 |
02-26-2020, 05:14 PM | #5 | |
Rep 1,254
Much appreciated
02-26-2020, 05:16 PM | #6 | ||
Rep 716
02-27-2020, 09:38 AM | #7 | |
Rep 7,487
In fact, the diagram and the numbers show that you will not get any additional "poke". The 20mm difference in width between your existing and new tires...will basically be negligible (based on the site's calculation)...and if you look at the illustration (of the tire)...the most poke will be just a little bit where the tire tread touches the ground & at the top. If there were a larger difference...you could see the outline of the original tire illustrated in orange....and the outline of the new tire illustrated in green. But since there won't be any additional poke...all you see in the illustration is the green since it is on top of the orange (in this case). To get another perspective of how the site can show the difference...just change one of the specs...like change the offset of the new wheel to ET33...then note how this can push the wheel approx 7mm out toward the fender. Hope this helps resolve any confusion you had about the site and its calculatiions.
philipm78581.00 |
02-27-2020, 10:05 AM | #8 |
Rep 697
Drives: 2013 535xi
QSilver7, your advice is always on target, but I'm not sure you have this one scoped correctly. The rim will not poke, as provided by the website, but the 305 tire, even per the diagram, will have a wider tread and will indeed stick out more than the 285 tire, by an additional 10 mm, or almost 1/2 inch. I believe this is what the OP is asking, and I have to agree with ey2001, based on his photo, that going up to a 305 tire is risky.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
02-27-2020, 10:16 AM | #9 | |
Rep 1,254
My wheels are fine not sticking out my concern was Tire If Tire will stick out If we talking only 10mm I think I will be ok
02-27-2020, 10:17 AM | #10 | ||
Rep 1,254
02-27-2020, 10:22 AM | #11 |
Rep 697
Drives: 2013 535xi
Here is another one of my favourite sites for comparing wheel & tire dimensions, which someone around here provided a while back. It provides quite a bit of information too!
Wheel Calculator
02-27-2020, 10:25 AM | #12 | ||
Rep 7,487
Also, the additional 10mm width of the 305mm tire is being stretched over a 10.5" wheel vs ey2001 whose 295mm width tire is stretch onto a 10" wheel. This will also affect the "poke" of the tire. There's multiple things to consider...hopefully ey2001 can update the thread with the specs of the tire that was on the left.
EL Jeffe 5611.50 |
02-27-2020, 10:32 PM | #13 |
Rep 716
It's pictures of the same side and the rear wheel.. just wanted to show different angles... but yes you are right 10.5 is little bit wide so it might have a slight stretch but I think he will still rub with 305... my 295/30/20 rubs slightly when I go over speed bumps with passengers in the back...
02-28-2020, 08:23 AM | #14 |
Rep 7,487
thanks for the clarification.
02-28-2020, 07:26 PM | #15 |
Rep 14,521
just out of curiosity since were talking 305's i'm actually replacing my tires this month and for the rear i'm already running 295/25/21 i'm assuming the tire will be slight taller going to a 305 but what would the aspect ratio be? i'm guessing diameter will be a bit larger now?
02-28-2020, 10:30 PM | #16 | |
Rep 1,254
02-28-2020, 10:34 PM | #17 |
Rep 1,254
I won't have to worry about If tire will stick out
I just found out I cracked one of my front wheels This was right after I installed new tires other day Now I'm in trouble they discontinued my wheels couple months ago I'm screwed I need new wheels now Fuck my life 😅
02-29-2020, 12:08 AM | #18 | |
Rep 716
EL Jeffe 5611.50 |
