2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Bavsound vs focal for f10
      08-14-2016, 01:36 PM   #1
creativ101
Drives: G30
Hi
Looking to upgrade my f10 speakers. Car currently has the basic stereo.
Don't really want to install an amp so it seems the two choices are the bavsound stage one (excl the rear speakers) or the focal ifbmw-s.
Any recommendations on which one? Price wise, they are similar.
      08-15-2016, 08:59 AM   #2
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
For me hands down Focals! Just my opinion tho but I just feel Bav is a great upgrade over stock but most guys go with it because of the convenience of the plug n play. I'm currently running Focal K2 Powers in my Titan
      08-15-2016, 02:36 PM   #3
xxpanipuri
Drives: 550i
+1 for Focals!
I've used them in other cars and always been happy with them.
BTW Focal has a plug and play solution for our cars.
Check this out
http://www.focal.com/usa/en/58-plug-play-
the bmw line is toward the bottom.
      08-15-2016, 06:10 PM   #4
lsturbointeg
Originally Posted by xxpanipuri View Post
+1 for Focals!
Check this out
Huh, I don't see the crossovers? Are they included?
      08-15-2016, 07:30 PM   #5
DigitalNav
Drives: 2013 535i M Sport
I want more of a deep bass when I crank the volume. Will bavsound do the trick? Just doing a sub upgrade.
2013 F10 535i M-Sport
Alpine White
Oyster/Black
OEM M5 Exhaust with Resonator Delete
      08-16-2016, 04:39 AM   #6
msfive
Drives: 2015 5281
Ifbmw-s will only fit on doors. And yes they do come w/ crossovers. If you want to change your center & rears you have to modify to fit! I use this k2's it sounded better then ifbmw. A lot smoother. For sub. Don't waste your money on under seat! Add a box @ rear. I had both ifbmw & k2's with focal under seat sub. Get the older k2's....you should still able to find them on sale & will be cheaper than ifbmw.
      08-16-2016, 08:34 AM   #7
creativ101
Drives: G30
Is the es100k a direct replacement for oem speakers?
      08-16-2016, 10:50 AM   #8
Silent_308
Knees in the Breeze
Silent_308's Avatar
Drives: 2011 F10
I'm assuming you want to be able to crank the volume, and bass with constant clarity over what your system already produces. If you add just a woofer (10 or 12 inch) you can get a nice deep bass reproduction, but at a certain point, you'll drown out the vocals and other instruments the highs and mids produce. If you want to just have more clean bass, add a powered subwoofer, like the JL Audio 10 or 12. The 10, will give you nice punch, with clean crisp response, the 12 will give you deep long thump. You just have to manipulate the "tone" settings in your idrive to clean it up or balance it out. I'm sure you don't want to be "that" guy sitting in traffic bass blasting with your trunk rattling like loose screws in a jar...
I added a powered JL sub, and upgraded my highs+mids to Focals in my E90, it sounded awesome for what I wanted. The 10 I had didn't take up much room in the trunk so it was still very functional. The only issue I had, but to this day I don't really know if it caused this, but my Alt and Battery both died out like 5-6 months after I put the powered woofer in... the battery was only 3 years old..
06 325xi R.I.P "you're in a better place now"
94 JDM DC2 (boost junkie) 12lbs Sun burst orange
"PLF and PFL are interchangeable terms when it comes to Holland DZ" -1SG Bailey 319th AFAR
      08-18-2016, 01:18 AM   #9
Takumi587
///M3 Enthusiast
Takumi587's Avatar
Drives: 05' M3 and 21' Tesla Model 3
I installed Bavsound to my car just about a month ago. I love how crisp and how much more bass it produces. No issues so far and it was pretty easy to install.
Sounds way better than my HK in the Merc ML550, JBL in the Tundra & the Bose in the E Class. No joke. Everyone compliments the sound system whenever they ride in my 535i.
delje08152.00
      07-02-2017, 08:12 PM   #10
TopQuark
Drives: 528i
Biased here since I went for Focals. Big improvement over the stock speakers with just the standard factory amp.
The IFBMW-SUB have less of an impact at the lower end but it made everything sound clear.
I set-up the back tweeters as follows and they look really cool!
      07-02-2017, 11:22 PM   #11
lsturbointeg
Attachment 1650078
Attachment 1650079
Very nice but you really don't need tweeters in the rear as the rears are basically for fill-ins. but i like what you did just for reference what Focals did you go with for the front and rears? add an amp and those Focals will take it to another level!
      07-03-2017, 09:16 PM   #12
Sylverlee
Drives: White 535i M-Sport, 911 GTS
[QUOTE=TopQuark;21900585]Biased here since I went for Focals. Big improvement over the stock speakers with just the standard factory amp.
Were you coming from base or premium audio?
      07-05-2017, 04:37 AM   #13
SilverRevlis
Motiphd
SilverRevlis's Avatar
Drives: F10 535 M Sport
Like lsturbointeg stated, you don't need tweets in the rear as the rear sound stage is already filled out very well OEM. I remember hearing Focals for the first time back in 2002 when I was deeper into car audio and SQ. My friend had a similar setup to what I had (I had all old-school Rockford Fosgate AMPS, subs and components in my Accord) but with Focal speakers......maybe because it was a VW Golf, but good grief the mids and highs were to a point I couldn't get in my car. And mind you, the mids in direct clarity would blow your mind! If Focal's products still have that same quality, definitely stick with Focal.
2016 535i xDrive M-Sport | 2016 328 xDrive w/Lighting (hers)
2012 VW Jetta GLI 6MT APR Stage 2 (retired) | 2012 VW Tiguan SEL 4Motion (hers/retired)
2012 Acura TL SH-AWD Advance (retired) | 2012 Acura RDX Tech (hers/retired)
2010 Acura MDX SH-AWD Advance (hers/retired)
      07-05-2017, 09:54 PM   #14
lsturbointeg
The Old Skool audio days were the $hits! MBQuartz before they sold, JL Audio before they sold, Fosgates, Polk Audio and remember Boston Acoustics? Im really wanting to go Focal K2 Powers in the Bimmer since im running them in my Nissan Titan. Love them!
      07-10-2017, 07:25 PM   #15
SilverRevlis
Motiphd
I remember Boston Acoustics! I was talking to the wife and I am seriously thinking about buying a 96-97 Accord sedan and do it up for SQ comp and mobile entertainment. MB Quartz was NO JOKE!!
      07-10-2017, 08:39 PM   #16
lsturbointeg
My wife had a pretty sweet setup for her 97 Accord. She had MBQuart components powered by an Old Skool PPI amp pushing Arc Audio 2 12" Arc Audio subs in a false floor. The Accord has stupid space in the trunk and would totally be ideal for SQ comp.
      07-14-2017, 02:10 PM   #17
ggonxhi
Drives: ggonxhi
i have the bavsound and love them. have not used focals
      08-06-2017, 10:47 AM   #18
lsturbointeg
Attachment 1650078
Attachment 1650079
which Focals did you go with BTW and from where? appreciate it!
      08-06-2017, 07:22 PM   #19
paul223
paul223's Avatar
Drives: F10
I got new set of authentic focal 4'' from ebay for $300 shipped.
      08-07-2017, 06:49 PM   #20
lsturbointeg
do you have a link Paul? also, were these specific for BMW or did you have to cut the connectors?
      09-06-2017, 11:43 PM   #21
BMWAUDIO
Drives: F90 M5 Frozen Gray , 997 C4S
The new model from Focal is the ES100K I do sell these at my store and can offer a discount to forum member
us serial numbers w/ full warranty
also have the lower lines available as well as Rockford T3 for bmw and HELIX for bmw
      09-07-2017, 05:43 AM   #22
lsturbointeg
PM me please for price!
What lineup does the ES100k compare to...K2, polyglass, access? Plug n play?
