2010 2011 BMW 5 Series Forum F10 found puddle of water in the car.. |
09-24-2016, 10:25 AM | #23 | ||
Rep 15,858
Leak was at the bottom section, leaking out from behind the bottom edge of the door card. Picture is dry after fix and water test, just showing position. Sorted it myself, as not sure it is even covered under the extended warranty. |
09-25-2016, 06:26 PM | #24 |
Rep 244
Do you have a part number or description? I don't see a "vapor barrier" on RealOEM or GetBMWParts, nor can a find a likely candidate looking through the part diagrams.
Mike
'04 330i ZHP '11 535i |
09-25-2016, 08:03 PM | #25 | |
Rep 4,553
Home Depot or an auto parts store will have RTV sealant. Remove door panel and hose down exterior of door. Watch where the water seeps in. Seal it up. Be sure to not lose the rubber bushings from the door clips. These need to be reinstalled or you may see water seep in through the clips. If for some reason your vapor barrier is badly torn or deteriorated, here's what you need. Realoem > vehicle trim > sound insulation
2023 840GC | 2021 740i | 2019 X3
09-27-2016, 06:50 AM | #26 |
Rep 581
I have had this problem on every single 5 Series we've ever had in the family. It's honestly ridiculous that something that plagued the E39 wasn't fixed in the F10 and continues to fail in exactly the same way.
It's very easy to fix and requires no new replacement parts. We didn't even use new sealant - just remove the doorcard, melt the existing sealant with a heat gun and re-affix the vapour barrier. You can reseal it with new sealant if you'd prefer but for me the reheat/restick of the existing sealant worked just fine. Bone dry after that. The fact it's such an easy fix makes it all the more frustrating that BMW don't fix it out of goodwill. Once you know what you are doing it takes 30 minutes. The bigger problem is getting rid of the dampness after!
Current: 2021 M340i xDrive, 2001 530i Sport
Previous: 2015 530d M Sport, 2010 530d SE, 2008 335i M Sport |
10-22-2016, 09:35 AM | #27 | |
Rep 29
How did you get rid of the dampness/water afterwards? |
10-23-2016, 05:35 PM | #28 |
Rep 581
A combination of a Vax vacuum cleaner (Dunno if you guys get them over there? It's a vacuum cleaner that can suck up water) and then running a dehumidifier in the car for a bit.
Then once that was that was done I drove around with the heater on max and the vents set to footwell only. A few days of that and it was dry again.
10-24-2016, 09:46 AM | #29 |
Rep 85
seems like a common problem with bimmers , i had a problem on my 545 where water was getting in the rear roof liner , my friend had this in his 550 e60 where we had to take out all the seats and carpet to dry it out cuz of the clogged drain tubes , and now my other friend experiencing this in his 2011 528.w
10-24-2016, 10:38 AM | #30 |
Rep 29
Yeah I think this is completely and utterly unacceptable and unforgivable, especially in a $75k car (or any modern car, for that matter)!
I have had this in all every one of my cars: E39, E60, and now F10. I told the lazy POS service rep at my dealership about it, and he argued with me, saying this is normal and not common at all, and I was "being to harsh and critical of the cars". None of my Mercedes or Lexus ever did that; hell, even my friends' Acuras and Infinitis never had this problem. BMW should be ashamed of themselves for allowing this to perpetuate, especially for such an easily fixable quality control issue that has been happening and persistent for almost 20 years. We need to get a petition signed perhaps? |
