2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes F11 20" offset
      03-07-2024, 08:26 AM   #1
ZeFix
ZeFix's Avatar
Drives: F11 525D
Hallo there!
Im going to look at a set of 20” rims in The weekend but im a little confused about the offset fitment
They are
20x10 285/35
and
20x9 255/40
Both offset 35
Will they fit a F11 525d rear wheel drive on standart springs?
      03-08-2024, 02:32 AM   #2
brad850csi
Drives: 16 F13 M6 Comp
Stock is 33mm offset with 245mm wide tyres so for the front you're 3mm further out than stock.
But for the rear which is 275mm and 44mm offset you'll be 14mm further out, this will mean that overall the rear will be quite a flush fit while the front will be very close to stock.
If you check out my post you'll see what 245mm on 20mm and 285mm on 32mm look like, my rear fitment is basically the same as yours but the front will look quite sunken by comparison.
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
      03-08-2024, 02:38 AM   #3
ZeFix
ZeFix's Avatar
Drives: F11 525D
But they will go on without any big problems?
Cant find the post😅
      03-08-2024, 03:03 AM   #4
brad850csi
Cant find the post😅
This post. https://f10.5post.com/forums/showthread.php?t=2085460
I think they will fit fine and look great at the rear but at the front you might want to run a 10-12mm spacer based on what I've found with my car.
ZeFix0.00
      03-08-2024, 03:37 AM   #5
ZeFix
ZeFix's Avatar
Drives: F11 525D
Great! Thank you so much for your help!
