2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Coding out EDC F10 SUCCESS!
      03-23-2017, 07:11 PM   #1
SLVSRFR
SLVSRFR's Avatar
Guam
245
Drives: BMW 550i
Putting this out there for anyone searching for this definite answer just as I was to no avail.
Coding out EDC on the BMW F10 is possible.
I have successfully installed Megan Coilovers and personally coded out EDC through ESYS.
My 550 is equipped with Adaptive Drive, Dynamic Drive, and Dynamic Damper Control(EDC)
I simply VO coded out 2VA, 229, and 223 of my FA
Calculated FA
Wrote the FA to the car
Coded the following ECU's:
DSC
HU_CIC
KOMBI
ICM
Errors are now gone, I lost the option of "Comfort" mode but Normal, Sport, and Sport+ are there and functional.
Thanks to @roskinc for letting me know that he coded EDC out of his vehicle as well.
      03-24-2017, 07:30 AM   #2
NvrNuff_ForMe
NvrNuff_ForMe's Avatar
Drives: 535i
Calculated FA
DSC
HU_CIC
KOMBI
ICM
I've got to say...your posting came at just the right time!
I will need to do this delete in about a week from now.
So thanks!
      03-24-2017, 07:37 AM   #3
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
That's AWESOME bro! now post those pictures!
      03-29-2017, 03:29 AM   #4
Teddylongtooth
ZEROdoubleZERO
Teddylongtooth's Avatar
228
Drives: 2011 550i m sport
Calculated FA
DSC
HU_CIC
KOMBI
ICM
Does your car have the hydraulic sway bars?
      03-29-2017, 10:35 AM   #5
SLVSRFR
SLVSRFR's Avatar
Guam
245
Drives: BMW 550i
I would assume so.
But it wouldn't matter now, if no signal goes to the sway bar, they go into failsafe mode and act as a normal sway bar.
      03-29-2017, 12:06 PM   #6
Sylverlee
Drives: White 535i M-Sport, 911 GTS
How do you like the Megan's?
      05-14-2017, 10:06 AM   #7
roskinc
Drives: e60
Glad it worked for you as well! I hated the error until I coded it out, and spent months trying get answers on coding it out.
I have kw v2 on my e60 and I have Megan's on my f10, and I love them. f10 rides way better than stock, super smooth. I'm gonna be adding m5 sways to make it even better.
      05-30-2017, 07:07 AM   #8
Willisodhiambo
Willisodhiambo's Avatar
Kenya
Drives: 2010 F10 535i, Most options in
I have a question here. This means your OEM shock absorbers are the electronic type. Right? Did you take a look at them? If you have replaced them it means you did not need to align the replacement as is required for the OEM? I am looking at DIY replacement later on but I fear doing so without some alignment tool mentioned in ISTA. I wonder is I could align by taking before detailed measurements of angles, lengths, positions e.t.c
      06-28-2017, 11:19 AM   #9
Stoich
Drives: F10
CIC to NBT
Hello,
I have change my system from CIC to NBT, in electric is everything OK, but i have no problems in coding, can anyone help?
      07-20-2017, 01:18 AM   #10
bmwfusion
Drives: 2012 bmw 535i
VNGVCE5, could you please, tell me what values did you deactivate in DSC, HU_CIC, KOMBI AND ICM? I have Done the first part with FA. But with these modules, i dont knwo what to look for in them. I looked for edc there.... i m trying to code out EDC on 2016 m235i . Right now i have chassis error on the dash and on control display and driving modes do not function (sport, sport+). Coilovers have been installed.
Please, help! I would greatly appreciate it. I ve tried looking for the info everywhere, but no luck.
Thanks.
      02-02-2018, 01:09 PM   #11
thakid22
Drives: 2021 Bmw M340i M-Sport w/ VDC
Calculated FA
DSC
HU_CIC
KOMBI
ICM
This deletes EDC. Does ARS remain functional?
      02-25-2018, 05:01 PM   #12
SLVSRFR
SLVSRFR's Avatar
Guam
245
Drives: BMW 550i
Calculated FA
DSC
HU_CIC
KOMBI
ICM
In my case, this deleted anything related to electronic suspension, not just EDC because I also removed DDC and Adaptive Drive.
Thanks.
Sorry for the late reply, not sure with newer cars but you don't change any values. You simply code the ECU's because you changed the FA, the car will write to the ECU's without EDC related info.
      08-06-2018, 02:31 PM   #13
Jahwrk
Drives: X5M
Calculated FA
DSC
HU_CIC
KOMBI
ICM
Thank you, I successfully VO coded these modules out on my friends 535xi and now he can enter sport mode
      03-17-2019, 03:40 PM   #14
badblack550xi
badblack550xi's Avatar
thank you for the guide coded mine out!
SLVSRFR244.50
      05-26-2020, 07:59 PM   #15
gabypr
gabypr's Avatar
Puerto Rico
150
Drives: Jet Black 2015 F10 535i
Calculated FA
DSC
HU_CIC
KOMBI
ICM
Sorry to resurrect this thread but I just wanted to know if after coding do you have to disconnect the EDC modules or vice-versa? Any other function is lost when deleting edc via coding?
CQuartz UK 3 Ceramic Coating | GeoShield Pronano 50% Ceramic Window Film | M5 M Perf Steering Wheel | M6 Comp Pkg Mufflers | M Perf Floor Mats | CF Spoiler | RW CF Quad Setup Diffuser | RW CF Front Lip | CF Trim | BMW Interior Leds | M5 343 Wheels | Pure Stg 2 Turbo
      07-25-2020, 09:40 AM   #16
misfitHERO
Drives: 535i
does anyone know if it works on bimmercode? ive tried looking but im not sure where to start
      09-01-2020, 01:31 PM   #17
Ratnik
Drives: 530 xD Msport 2016
Cant do that with bimmercode bro. must have esys, pm me i can help you
if you have enet cable
      01-09-2021, 12:15 PM   #18
TechnoTuup
Drives: BMW 535i M-Sport F10
Hi Ratnik. I have an ENET cable. Can you help me with programming this error out?
To everyone: What does FA mean and how do you calculate it?
      01-12-2021, 09:14 PM   #19
Jamesmick
Drives: 2018 M5 Azurite Black
I recently add Bilstein coilovers on my 535i M-Sport and coded out my EDC. It left me with Eco, comfort and sport, but I lost sport+. Strange.
2018 M5 (current)
2012 535i Msport/Dinan (current)
2008 535i Msport (retired)
2003 530i (retired)
2000 C32 AMG (retired)
      04-06-2021, 12:20 PM   #20
skohlhepp
Drives: BMW 535i
Anyone here that has done this should be able to answer, but did you have to unplug anything or just code it and it will work? Also you can use BimmerCode to add sport + back in if that’s something you want. I forget exactly what module it’s in but it’s definitely there.
      06-03-2021, 05:41 PM   #21
BoogeyMan'sBMW
BoogeyMan'sBMW's Avatar
Bangladesh
118
Drives: SLOW
Not sure if you can use BC to code Sport+, but you can use it to enable SAT which isn't entirely the same.
      09-04-2021, 03:02 PM   #22
Rogue75
Drives: Toyota Tacoma
About to code out edc. Does the module need to be unplugged aswell?
