2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 20 inch Wheel Fitment Question.
      07-26-2020, 04:36 PM   #67
tonytony99
tonytony99's Avatar
Drives: 2014 528i
Unhappy 2016 528i NEED HELP
Hey friends, been reading a lot and still have no answers
About to order some Niche 20x10.5 and 20x9 +35 offset on front and rear.
I was going to order 255/35/20 Nitto 555G2 for front and 285/30/20 for rear.
Few questions, dropping the car on coilovers, will this setup rub?
Also, will 255 and 285 be stretched a little, do I need a 265/35 and 295/30 instead for it to be flush?
Im sure these would fit just fine at stock height I am just worried about fitment after dropping the car?
Any feedback or suggestions please!!
      07-26-2020, 05:33 PM   #68
tonytony99
tonytony99's Avatar
Drives: 2014 528i
Front setup?
Originally Posted by M335 View Post
20x10.5 +42 with 305 on the back on stock M suspension 👍🏻
What size wheel and tire are on the front?
      11-01-2020, 10:22 PM   #69
Eadames
Drives: BMW 528i
Hello Gentlemen,
Want to install different wheels on my 5 series.
Front: 8.5x20 ET38
Rear: 10x20 ET51
Will these wheels fit my car? And what size tires should I put on?
      01-24-2022, 07:59 AM   #70
bamberjim
Drives: 2012 F10 535D
255/35/20 front and 285/30/20 for rear. genuine M5 wheels no rubbing on Eibach pro sport springs
      02-27-2022, 08:20 PM   #71
Eddiek550
Drives: BMW 550i xDrive F10
Can anyone provide some insight on what tires to go with?
I want a thicker side wall. I had 245/35/20 and 285/30/20 Super Sports and ended up blowing out each front (separate occasions but both at night - hate NJ roads). Being that I am AWD, i calculated that i can run a few different sizes but the question is will it rub - i am not currently lowered as i want to save getting springs until i figure out tires (i.e. if tires fill the gap on their own then i won't get springs)
Wheels are HRE FF04 20x9 ET25 front and 20x10 ET40 rear.
Can I run the following without rubbing?
255/40/20 (28" height)
295/35/20 (28.1" height)
I know brand and model tire matters as well and to be honest, i was not a fan of the super sports. Sport 4s is what i am looking at currently, but would like advice on other brands/models.
Main concerns are to avoid spinning on launch (in awd) and avoid spinning on 40/60 rolls (in RWD via xDelete) while also resisting potholes more than before (if possible).
Any and all suggestions appreciated!
2012 BMW 550 xDrive | n63intake.com goodies + tune | M5 Comp Exhaust | xHP stage 3 | xDelete | 20" HRE FF04
      03-07-2022, 05:13 AM   #72
slev1111n
Drives: bmw x5
Tnx for the info guys! It really helped my friend. we argued about it for a long time and in the end he agreed with what is said here
      03-11-2022, 08:55 AM   #73
Taylorguy74
Enthusiast
Drives: 2016 550i M-Sport
20x10.5 +42 with 305 on the back on stock M suspension ����
How far does that stick out? Is the wheel flush, or protruding outside of the lip of the fender? Do you have any pics you could share? I'm considering a similar ET, just with a 285 or even 275 tire.
2016 550i M-Sport
2008 328i M-Sport (Sold)
2007 Z4M Roadster (Sold)
      03-13-2022, 08:31 PM   #74
Dif-one
Drives: 2013 550i
Hate to hijack threads but currently running’s 20x9 245/35 ET35 fronts and 20x10.5 285/30 ET42 rears. I feel like I have room to be a more aggressive with the fitment. I’m lowered on H&R springs. How aggressive can I get front and rear? I see ET25 fronts but rears? ET 35?
      04-17-2022, 02:47 AM   #75
Bitchn5ive
Bitchn5ive's Avatar
Drives: F10 550i xdrive
Originally Posted by Bitchn5ive View Post
Can I throw one out here:
I have 20x9 et 30 and 20x10 et 38 on a 550i xdrive lowered on ACS springs.
Currently on 245/35 and 275/30 w/o issues but want to go a bit wider.
How do you think 255/35 and 295/30's work out?
Thanks in advance!
Just following up to confirm this works. No rubbing so far and I don't think it will. It is tight though.
Continental Extreme Contact 255/35/20 Front and 295/30/20 Rear with 20 x 9 et30 and 20 x 10 et38 respectively. Some pics:
Jacked up from opposite side to check clearance...
Sitting normal...
      03-14-2024, 09:14 PM   #76
RalphgF10
RalphgF10's Avatar
Drives: 2012 BMW 528i F10
Originally Posted by JayBimmer83 View Post
Love the Niche wheels. I have the same ones but all black. I got the 20x9 square set.
Is that 20x9 +35 cause I want the same size but the Niche Gamma
