2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications BMW Transmission Fluid & Differential Fluid Change question. 2011 BMW 535i xdrive
      08-26-2020, 07:03 AM   #23
Surly73
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
Originally Posted by 535_BiTurbo View Post
You didnt reset the transmission adaptations at all right? Just changed the fluid only
Changed pan and fluid, final level check using ISTA+.
Since you have an ATF/coolant heat exchanger instead of ATF/air, you may have to work significantly faster than I did to get it done within the acceptable temperature range. This was my experience years ago with an E39 540i with ATF/coolant exchanger.
Tags
2011, bmw 535i xdrive, f10, transmission fluid
