2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Drivers side headlight condensation..
      02-07-2022, 02:54 AM   #1
JoeyF30
Drives: BMW 2013 328i xDrive N26
Hello all , my f10 2014 has the adaptive LEDs and I was blessed with condensation in the headlight and got all the warnings that came with it… what should I do to fix this? I live in NJ and am willing to travel to NY/PA etc if need be to get the TMS Module replaced and headlights resealed. A brand new light is outrageously expensive so I would prefer a used unit and then have the reseal procedure done. I had condensation in the headlight since I bought it but always went away, however the weather got wacky here plus I took it to an auto wash and drove through a pothole with a puddle that splashed water up on my drivers side headlight. Any help would be appreciated
      02-18-2022, 01:58 PM   #2
J-Pizzle
Drives: F87 M2
2018 BMW M2  [0.00]
2018 BMW M3C  [0.00]
2020 BMW X3M  [0.00]
Unfortunately I think you are out of luck in this case. Since the headlight assembly is one piece hermetically sealed, once you can condensation inside I think you will forever have it there and would need to get it replaced. Sealing it again would just seal the moisture in unless you have a process to suck the humidity out before resealing. Good luck and let us know if you are able to fix it without replacement.
      02-22-2022, 04:32 PM   #3
chipguy
Drives: 12 528i
This is what is needed if you want to save your headlight.
      02-22-2022, 07:33 PM   #4
TZ
Drives: 2011 535i xDrive, 2014 435i CO
Remove the lamp module top cover will let the moisture dry out. Now I open a small hole on the top cover. Would like to see if the condensation comes back.
2014 435i RWD Convertible
Service Manual: www.newtis.info
Part: http://www.realoem.com
      02-23-2022, 12:59 PM   #5
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
Remove light and send off to repair. Bumper does not need to be removed
