2010 2011 BMW 5 Series Forum F10 Fog light delete covers. |
11-21-2018, 04:56 AM | #1 |
Rep 99
Drives: 2015 550i
can anyone link a site for legit f10 m sport fog light delete covers. thanks
11-21-2018, 01:16 PM | #2 | |
Rep 5,365
11-22-2018, 02:39 PM | #3 | |
Rep 7,487
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
11-23-2018, 10:49 AM | #4 |
Rep 99
Drives: 2015 550i
11-24-2018, 12:35 PM | #5 |
Rep 639
Just an FYI, I was looking to do the same to my car, but found out that one cover is vented and the other side cover is solid. On my car I have an oil cooler behind one fog light and an additional radiator behind the other, so by installing these I would be completely blocking airflow to the one side radiator. Unfortunately I haven’t found any of these that have both sides vented.
You’re car may not have something behind each fog light, but just wanted to make you aware if this potential issue. I believe this is the part number for the right side 51118055134 Left side is the solid one and is part number 51118055133 You can find them online from different shops and on eBay Last edited by SWFLf10; 11-24-2018 at 12:46 PM.. |
11-25-2018, 10:50 AM | #6 | |
Rep 99
Drives: 2015 550i
11-25-2018, 09:53 PM | #7 |
Rep 5,365
It's all based on what's behind the grille. Our 2012 base 535i has a "vented" grille on the right and a "blank" grille on the left. You have a cooling "device" behind each grille.You could always buy the blank and drill out the blocked off portion.
11-27-2018, 06:02 AM | #8 |
Rep 639
11-21-2020, 07:12 PM | #9 |
Cole
321
Rep 498
So I know this is an old thread, but I wanted to post what I did incase someone is searching for options and comes across this thread. I pulled the fog lights and their trim out, removed the brackets for the fog lights, tucked the wires up, and very carefully used a dremel to cut out all of the inside parts of the trim piece. What I ended up with is just a trim piece that covers the edge of the lower bumper holes. I sprayed the oil cooler radiator and the power steering radiator black and re installed everything.
My 2012 550i has a radiator behind both fog lights so they both had to be open. Last edited by AnotherM; 11-24-2020 at 08:28 AM.. |
11-23-2020, 09:41 PM | #10 |
Rep 423
Does anyone know if these fog covers are available without the fins? I would prefer a plain mesh look.
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771 MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster. |
11-23-2020, 10:54 PM | #12 | |
Rep 204
11-24-2020, 06:00 AM | #13 |
Rep 423
Yes. Will these work on a LCI M Sport bumper? Also, do you have a link?
11-24-2020, 08:27 AM | #14 |
Cole
321
Rep 498
11-30-2020, 10:12 PM | #15 | |
Cole
321
Rep 498
So tonight I took two fog covers, trimmed them down with my dremel and began filling them with fiberglass to create the deeper trim piece that will be my skeleton to wrap this weekend. I only did the bottom section, but here's how it's going so far. The carbon fiber fabric and epoxy resin will be going on this weekend so I will hopefully have the skeleton completed by Friday. Last edited by AnotherM; 11-30-2020 at 10:18 PM.. |
SWFLf10373.50 |
11-30-2020, 10:38 PM | #16 |
Rep 423
Very interesting! Looking forward to seeing this project!
11-30-2020, 10:56 PM | #17 |
Cole
321
Rep 498
I'm contemplating adding the hex grille behind it to protect the coolers. Seems I can get a large sheet of the identical material for around $40, but I just drove almost 1500k miles without them and didnt even have a bug in the coolers so I'm not sure if I want to spend the time plastic welding them into the back or not.
12-01-2020, 07:19 PM | #18 |
Cole
321
Rep 498
Some pictures during the fiberglass phase. Extending and creating a deeper trim piece to wrap. Next sanding, bondo, sanding, and finally primer. Will be ready to wrap by tomorrow.
12-13-2020, 11:43 AM | #20 |
Rep 423
Any updates on this. I'm really liking the progress.
I went ahead and ordered the delete covers shown above.
12-15-2020, 07:23 PM | #21 |
Rep 423
Took a little less than 2 weeks .
12-19-2020, 03:40 PM | #22 |
Cole
321
Rep 498
I thought about using those and may still end up using them.
So I ordered the hex plastic sheet and am going to weld it to the back of the new trim. I dont like how this finished so i am going to redo it again. I think it will look nice when its finally finished. Last edited by AnotherM; 12-23-2020 at 11:04 AM.. |
