2010 2011 BMW 5 Series Forum F10 Possible blown Head Gasket???....Hope not |
12-11-2021, 12:41 PM | #1 |
Rep 504
Drives: 2013 BMW F10 N55 535i XDrive
Hey guys...tough couple weeks here for my F10...not 100% sure..but possibly have a blown HG..anyone hear of this on N55 with 90k miles...I had smoke coming from car when started up lately..had oil on downpipe from when I changed to VC..thought it was burning off..but yestetday and today had white smoke coming from exhaust when hitting gas..almost threw up when I saw it....car hasn't overheated..and just pulled plugs..they are dry with just normal wear on them from having them in... coolant level is at minimum in reservoir..I just topped up now..what else could be causing this smoke??..oil just got changed exactly 105 miles ago
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
12-11-2021, 05:38 PM | #2 |
Rep 832
Several ways to go about making sure, but it should be based on.....data.
Running your engine hoping that it goes away should not be option 1. A compression check is rather easy to do, but does involve pulling your spark plugs and a $15 compression gauge will do.... ....or you can keep wondering (or hoping that it isn't). Cheers Last edited by M_Bimmer; 01-29-2022 at 06:05 PM.. |
musclesmarinara75206.00 |
12-11-2021, 06:49 PM | #3 |
Rep 5,366
12-13-2021, 06:32 PM | #4 |
Rep 504
Just had the plugs out, checked the combustion chamber with a bore scope, didn't find anything on either, didn't even think about a compression check, that's my next step, thanks guys!!..hopefully it's nothing to crazy
01-28-2022, 02:12 PM | #6 |
Rep 68
Drives: 2011 535ix M-sport
In person, it might be easier to diagnose, but here are some desktop diagnosis things to consider. Oil on the downpipe sounds independent of white smoke coming from the tailpipe. Oil in the downpipe could also signal something independent.
Have you also checked the coolant reservoir if you see floating oil? White smoke could also mean condensation from the cold weather in the exhaust system. Have you done the oil filter housing gasket, which I believe could cross oil and coolant? Did you smell the oil to see if it smells sweet? You can unscrew the filter for this since it doesn't have a dipstick. But.....since you are running Pure Stg 2 with increased boost, it wouldn't be out of the question it's a head gasket. Compression test could help in this, but is not always certain.
'11 535ix M-Sport - FMIC, CP, BM3 engine & trans, CQuartz Finest Ceramic, Poly tension bushings, Dynamic, Active Roll, Flappy paddles, HUD, Premium(s), Cold, Convenience, 5-cameras, 4-zones, Driver's Assist, Auto high, Hex trim
'92 850i, '08 XC90 3.2 Past: '93 525i w/ S38B36 M5 engine/trans swap, '99 540i/6sp Sport, etc. |
01-29-2022, 03:57 PM | #7 | |
Rep 504
01-29-2022, 09:50 PM | #8 |
Rep 915
Definitely sounds like blow by of some sort.
Instgram @burninja
01-30-2022, 10:00 AM | #9 |
Rep 504
Yea... went crazy chasing this down, even insalled an OCC and totally dismissed the turbo cause it was new...ended up being the PS2...anyways.. all the stuff I replaced was gonna have to be replaced sooner or later... glad its done now
BurrNinja430.50 |
01-30-2022, 06:03 PM | #10 |
Rep 504
your burning oil??.. or coolant in your oil?
02-01-2022, 09:09 AM | #12 |
Rep 504
...if you don't have oil in your coolant, and it's not burning oil... what's your problem???....LOL
02-17-2022, 07:38 AM | #13 |
Rep 10
My problem is a tak tak after 5 min from coldstat, but if you turn it a little bit, the noise goes away, even with the hood up. The noise seems to be coming from the oil filter holder.
