2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum LPFP Wires cut and spliced
      02-21-2022, 09:05 PM   #1
calswan7145
Drives: 2011 535xi, 2009 328xi
My fuel pump went out on the highway, without warning I might add. As a result I’ve done a ton of maintenance over the past week. Tonight I changed the LPFP. After removing the cover under the rear seat I noticed the wires were wrapped with electrical tape and there was wire insulation around the pump seal. I unwrapped the wires and they had been cut and crimp connected back together. I’m just confused. Why would the previous owner or maybe a shop do something like this? If someone had installed an aftermarket pump I would think the wires would be cut in the tank. Not the factory plug on the outside. Can anyone on here think of a reason my car would have had the factory pigtail cut off at some point?
      02-21-2022, 09:40 PM   #2
ceka
ceka's Avatar
24
Drives: 530d 11'
When searching for used parts on eBay, I see most of them cut them like that, so maybe it's a used pump from another car spliced to your car.
      02-22-2022, 12:15 AM   #3
Hoa
Your original connector was probably damaged so they replaced it
      02-22-2022, 06:14 AM   #4
calswan7145
I've had the car since about 30,000 car has 96,000 now, I'm not exactly sure on the lifespan of an OEM pump but I was assuming it was still the factory pump before I opened it up. Seems unlikely the factory pump would have gone out in the first 30,000 right?
      02-22-2022, 10:13 AM   #5
Hoa
It can on earlier models. I've had a 2013 535I that needed 2 fuel pump replaced within 15K miles. My 2014 (LCI) still have original pump and I'm at 299K miles
      02-22-2022, 11:56 AM   #6
calswan7145
Good to know maybe I’ll order another one just to keep around.
