2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 550i n63 power record
      11-21-2016, 04:47 PM   #23
phil7027
Drives: 2015 550xi
Originally Posted by FSociety View Post
I also wouldn't cancel a ECU tune, JB4 is very inconsistent. They put down great power on Dyno but on the street or 1/4 mile you'll be surprised. Most of these cars running consistent 1/4 mile on their car are pushing so much boost on the jb4 that a flash would require less since its also modifying proper parameters and tables.
I had my appointment with Mo at DME but cancelled it just because i didnt see TOO much of a benefit to drop 1800. But if I do these turbos AND get the full ECU tune I may be in luck. I just dont want to break anything in the process
2015 Alpine White BMW 550XI Msport
BMS tune, Catless Downpipes,Full Custom Exhaust, H&R springs, Avant Garde M359 Wheels, M5 Diffuser & Spoiler
2016 Race Red F-150 XLT Sport
      11-21-2016, 04:53 PM   #24
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
I agree with you now, btw you didn't reach out to Enzo or RKTunes? I know ARC550 had EnzoTuned on his 550 or you could wait for proTUNING Freaks Bootmod3 to release their N63Tu .
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      11-21-2016, 04:56 PM   #25
phil7027
Drives: 2015 550xi
Many have said to stay away from Enzo, and I have not heard too much about the n63tu tunes for rktunes so I kind of dont want to be the guinea pig. Mo is tuning all the fastest m5's so I know its a different platform but he has to be doing something right
      11-21-2016, 05:31 PM   #26
wakeofdeath
Albania
71
Drives: X6M
Many have said to stay away from everybody; nobody is going to be 100% pleased ever. Plenty of M's tuned by Enzo, a few from RKtunes. DME is called "Slave" because they don't tune, they copy & paste as they're "Slave" tuner of BR-Performance. EndBosS
Long story short, $1800 is steep without seeing a single N63Tu tuned by them.
FSociety3812.50
      11-21-2016, 06:26 PM   #27
550Reasons
550Reasons's Avatar
Drives: F10 550i
how is the transmission holding up ?
2011 550i
2013 M5
2014 M5 CP
2016 550i
      11-21-2016, 06:32 PM   #28
badblack550xi
badblack550xi's Avatar
he just got his car back we need to give him a few weeks to be certain.
2011 550i RWD 60-130 7.35
      11-21-2016, 08:07 PM   #29
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2019 M2 Competition  [0.00]
2002 330ci  [0.00]
Im also confused.... They make a better jb4 for the n63 but not the n63tu. Why can we change settings and datalog on the n63 but not the TU?
you can change the settings on the TU JB4, you have to open the tuner and adjust it.
      11-21-2016, 09:45 PM   #30
ARC550
Drives: M3, X5, 720s, X5, 750xi
I had the TU and I was able to stack JB4 with tune. The only way to change boost was to open the little boxes and increase dial.
Also, the transmission will hold as its comparable to X5M... the Transfer case will Not. I broke my transfer case on dyno lol
FSociety3812.50
      11-21-2016, 11:50 PM   #31
747flyboy
Drives: 2008 M3 2012 550i M
Stock Turbo PSI
what psi can the stock turbos go up to ?
Hello there bud,
Now that we have 3.5 BAR sensors, the sky is the limit. Stock Turbos will go as far as you consider safe. 3.5 BAR is approximately 30 PSI at 5 volt scalar.
You loose little linearity but close enough. Just have to consider Octane,fuel delivery, pre-ignition/timing, AFR ect. Tuning is key and fortunately for us JB4 MAP6 may have an answer.....Exciting stuff.
      11-22-2016, 12:19 AM   #32
phil7027
Drives: 2015 550xi
So what would be a fix for this? Or just stay at the power were at for drive cars lol? I don't want to drop the money for the turbos and a tune if I already know the transfer case is gonna go in no time. Any way to unhook the AWD shaft and make it RWD without changing anything?
      11-22-2016, 12:20 AM   #33
ARC550
Pay to play broski!
My transfer case broke after 200 1/4 runs and 100 dyno sessions and beating the fuckin piss out of it and 500+ launches
All depends how you drive lol
      11-22-2016, 12:27 AM   #34
phil7027
Drives: 2015 550xi
Pay to play broski!
Got a hookup incase mine does ?
      11-22-2016, 12:27 AM   #35
ARC550
Pay to play broski!
Ahahahaha.. you could say that lol
      11-22-2016, 12:30 AM   #36
phil7027
Drives: 2015 550xi
Anything you didn't like about the Enzo tune? Did they throw the car on the dyno and tune it, or was just a generic flash like the DME tune? I wonder if they can tune for the new 3.5bar sensors
      11-22-2016, 12:55 AM   #37
747flyboy
Tune
Just go with JB4......Multiple safe options based on driving habits and desires.
It is 3.5 BAR TMAP sensor setup ready. I pulled 562 WHP with wheel slippage and 2.5 BAR sensors. The other dude is correct, everyone is cutting and pasting calling themselves tuners. Whatever floats your boat,at $799 you cannot go wrong and not have to break anything.
      11-22-2016, 07:36 AM   #38
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
phil7027 with the new Bootmod3, Enzo can tune you remotely too or whoever is a Bm3 Tuner/Dealer since they go by the logs just like Terry does it with JB4 logs. Logs say more than a Dyno
Cars drive so different on the street than on Dyno you can miss something. Although a Dyno is a must to see the powercurve and make sure no misfires on that too.
they use Flex-ray which is a technology the same way u code a car too, their flex ray is 8-10Hz, Jb isn’t even at 1 sample a second just so u can have an idea to be more accurate 0.3 samples a second hahaha … if it wasn’t for the DME being so fast to save motors from knock jb wouldn’t exist lol. bm3 is logging over 200 channels, basically bm3 logs everything the ecu itself sees every channel (including Knock and Timing Corrections)
IG: @bmwF9XG80
      11-26-2016, 06:16 AM   #39
saleen751
Drives: 2005 545i
Are we taking n63 or n63tu? This is a n63 thread not tu. So start a new thread if needed because last time I checked nobody could do this for the n63.
      11-26-2016, 10:12 AM   #40
badblack550xi
this is n63
      11-26-2016, 01:31 PM   #41
MattPro
MattPro's Avatar
Drives: '13 F10 550iX, '91 E30
This has definitely inspired me to go meth, I ordered the BMS setup. I'm really unhappy with E85. Inconvenient, bad mileage, and the car runs weird on it.
I guess we will see what the Alpinas, x-drive, and meth can all do together.
Thanks,
Matt
2013 F10 550iX Carbon Black/MSport
BMW Fault Code DB
      11-26-2016, 07:33 PM   #42
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Damn thats crazy can you make video
      11-26-2016, 08:58 PM   #43
saleen751
Drives: 2005 545i
Does anybody know which is bank 1 on a US n63? I'm getting a drivetrain error and the code that comes up is bank 1 misfire. I just changed all the plugs and coil packs 2 months ago. If I'm looking at the front of the engine I changed the first spark plug on the left side of the engine and it's still giving me the error. The drivetrain error comes on about a minute after I start the car without even driving.
      11-28-2016, 12:01 AM   #44
ARC550
You need a Real* tune.
Or your Jb4 wires/device is in bad shape.
