2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N63 Meth Injection
      12-06-2016, 04:14 PM   #1
MattPro
MattPro's Avatar
Drives: '13 F10 550iX, '91 E30
N63 Meth Injection
Figured I would make a thread like BadBlack's old one to keep track of my adventures with meth.
The BMS kit just arrived in the mail, along with a set of M5 MAP sensors for the charge system.
View post on imgur.com
Since I'm x-drive I'm not sure how high I want to go. I'd like to break 600awhp for a dyno pull but then probably keep it around 550awhp for daily usage so I don't destroy my transfercase in a week.
I'll update this thread as I make progress this month!
Thanks,
Matt
2013 F10 550iX Carbon Black/MSport
BMW Fault Code DB
      12-06-2016, 08:54 PM   #2
badblack550xi
badblack550xi's Avatar
nice! i still have my meth kit collecting dust. good luck and keep us posted.
2011 550i RWD 60-130 7.35
      12-13-2016, 10:40 AM   #3
mikekilpatrick
mikekilpatrick's Avatar
Drives: 2013 BMW F10 550 Xdrive Msport
Yes, this is on my list as well after the other mods. Please keep informed and maybe document on the install please.
      02-22-2017, 06:04 PM   #4
MattPro
MattPro's Avatar
Huge thank you to 747flyboy for getting me a set of intercoolers and charge hoses.
Thank to him I was able to move forward with my installation after a couple months of being away.
I opted to spray the meth after the intercooler cores, or directly before the throttle body. I decided on this for two reasons,
1. If sprayed before, the cooler mist/air combination would pull heat from the intercooler core since the water temp would be warmer
2. The possibility of methanol pooling in my intercoolers
Also took this time to wrap my intercoolers/intake piping in heat reflective tape and install my 3.5bar TMAP sensors.
My current status is the CM10 nozzles I ordered seem to be a bit too big for the N63 flow. I am currently getting spark blowout on higher boost/meth flow. I replaced all spark plugs with N20 plugs (2 steps colder) and gapped to .020" and replaced all coils with a fresh Eldor set with no help. So I think there is just too much meth being sprayed in currently.
Thanks,
Matt
BMW Fault Code DB
      02-22-2017, 06:07 PM   #5
MattPro
MattPro's Avatar
Huge thank you again to 747flyboy for the intercoolers and Terry @ BMS. He has been helping me get the N63 JB4 firmware set up to control the BMS meth kit properly. The BMS meth kit was quick and easy to install, however I think I will need a couple extra feet of hose to get the tank in a perfect spot in the trunk. I used every foot they sent.
Hopefully Terry can help scale the meth flow a big to control my blowout. If not, I can always downsize in nozzle.
Thanks,
Matt
BMW Fault Code DB
      02-22-2017, 08:22 PM   #6
747flyboy
Drives: 2008 M3 2012 550i M
Welcome back Matt. You were thoroughly missed.
      11-25-2017, 09:13 PM   #7
M335
M335's Avatar
47
Drives: E90 n55 IG@FrozenF10
Any updates on meth injection?
      11-26-2017, 11:37 AM   #8
BDJL
Drives: 2011 550i 6MT, 2017 X1 M Sport
Yeah, I am really looking forward to some more information!
      11-27-2017, 09:54 PM   #9
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
I learned that CM10's are too big for even most M5 guys; CM7's should be sufficient.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      11-28-2017, 02:05 PM   #10
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
Nice setup!
