2010 2011 BMW 5 Series Forum F10 X-pipe To Help With Drone? |
01-02-2017, 12:40 AM | #1 |
Rep 154
currently have RPI mufflers on my 550 and im having drone around 1.5-2k rpm. after looking around on the forums some people are saying that replacing the resonator with a x-pipe helps with drone at low RPM's. Does anyone have any a x-pipe set up that can tell me if it will help with the drone issue? thanks and happy new years everybody!
01-02-2017, 01:38 AM | #2 |
Rep 1,085
Drives: 2013 BMW F10 550 Xdrive Msport
Do you still have the vacuum enabled WOT valve on these mufflers? Or do they delete it? I had the SAME issue with a name brand muffler at same speeds and once I switched to Dinan, which uses valve control on two of the muffler exhaust ports, the drone was greatly reduced at low rpms
01-02-2017, 12:05 PM | #3 | |
Rep 154
01-02-2017, 04:16 PM | #4 |
Rep 1,890
X Pipe will help equalize the airflow so yes, in theory, it will help a TAD. Your best bet is a J Pipe. Lookup "J Pipe Drone" and you'll see its success on many different forums including my own car. You'll need to go to a competent exhaust shop that isn't afraid to do some custom piping.
01-02-2017, 09:35 PM | #6 |
Rep 154
01-06-2017, 01:25 PM | #7 |
Rep 216
Not to compares bratwurst to cheeseburgers, but when I replaced a damaged H-pipe on my Mustang with a sleek-new X-pipe the drone became almost unbearable. YMMV.
01-06-2017, 06:56 PM | #8 | |
Rep 163
I think that's part of the reason why exhaust setups for our car are so expensive, because of the engineering that goes behind them.
01-07-2017, 02:05 PM | #10 | |
Rep 154
01-08-2017, 02:05 PM | #11 |
Rep 357
Drives: 19' M2C
i am getting bad drone also at the 1.5k to 2k on my cat back M5 CP exhaust. don't know what to do either.
02-20-2017, 09:04 PM | #12 |
Rep 1,585
Did you ever figure out what to do with the drone? I'm getting the drone as well in the same RPM range. I already permanently removed the exhaust valves when I had the tips installed. Would partially closing the outside tip possibly remove some of the drone or would it create a whistle sound? Only other thing I can think of is to retrofit the valves I have left from the 550i...
02-21-2017, 11:15 AM | #13 | |
Rep 1,890
02-21-2017, 11:53 AM | #14 |
Rep 154
I installed a custom fabbed x pipe last week and it really woke my exhaust up! It has a deeper growl to it now and it helped get rid of drone as well. It has a nice deep exhaust tone in the cabin now instead of that loud exhaust vibration sound that it had before! Will definitely be posting videos soon!
delje08152.00 |
02-21-2017, 01:36 PM | #15 |
Rep 1,585
02-21-2017, 01:37 PM | #16 | |
Rep 1,890
02-21-2017, 02:14 PM | #17 |
Rep 1,585
I know, it was connected. There wasn't any noticeable sound improvement with the valves closed, which is 90% of the time. That's the reason why they were removed all together.
02-21-2017, 07:35 PM | #18 |
Rep 544
I just keep the car in SPORT mode...higher RPMs=No drone!
By manually shifting, I keep the rpms just above 1900 in all gears which eliminates the drone. The engine sounds so much better above 2k rpm anyway
Project Gamma Intakes / Project Gamma Catless Downpipes / Muffler Delete / DME Stage II Tune / H&R Springs |
02-21-2017, 08:04 PM | #19 |
Rep 1,585
I noticed that, too. Do you still have the valves or did you remove them? Car sounds great over 2K RPMs with no drone.
02-21-2017, 08:09 PM | #20 | |
Rep 544
Sport mode is much more fun and car sounds great!
02-21-2017, 09:44 PM | #21 | |
Rep 357
Drives: 19' M2C
02-22-2017, 10:20 AM | #22 | |
Rep 1,585
