2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Does anyone know the trick to releasing the airbag?
      03-02-2011, 05:02 PM   #1
///M5Canuck
Drives: BMW 535i xDrive
I was looking to swap steering wheels in my F10 and there is NO DIY online yet for this model of steering wheel. I think I could get through most of it, but no idea how to get the airbag to release from the wheel. If anyone could help, I would greatly appreciate it. Cheers.
      03-02-2011, 05:08 PM   #2
Touring
Touring's Avatar
Norway
106
Drives: i3,E21,M2,E23, Skoda Kodiaq
Crash into a wall at 30mph
      03-02-2011, 05:36 PM   #3
///M5Canuck
I like your creativity
      03-02-2011, 06:39 PM   #4
ghueser
Drives: 2014 M5
There should be two or three small "holes" on the back of the steering wheel where the attachments are located. The big question however is what kind? Do a google search on replacing BMW steering wheels. I also think there were some DIY replacement instructions on BMWTIPS.com that you could reference.
Older cars with airbags, but most likely similar if not identical to what we have.
      03-03-2011, 12:00 AM   #5
///M5Canuck
I have found they are not similar at all. I have tried referencing all the DIY forums I could find, nothing on the new wheels. This was sort of confirmed today by BMW when they told me I would need a special tool. Not sure I believe that, but on the newer 3-series it is a matter of releasing a spring. Thank you for your suggestion
      03-03-2011, 11:04 AM   #6
grimlock
Drives: F10 N52B30@255PS
if it doesn't trigger, back up and repeat at 40mph... u get the idea
      03-03-2011, 12:28 PM   #7
ghueser
Drives: 2014 M5
There is a picture of the back of one on E-Bay. It might give you some clues.
      03-03-2011, 02:32 PM   #8
///M5Canuck
Well, I have the M wheel apart that I am going to put in the car and I still can't figure it out....I cannot for the life of me see how to get in there and release the spring. Thank you for the idea though.
      03-03-2011, 02:39 PM   #9
ghueser
Drives: 2014 M5
For the safety factor of the airbag alone, take it to the dealer and have them do it. Just talk to the shop manager and he will probably work a deal if he is at all resonable. (most are in my experiences) It does look like it takes a special tool and for a half hour or hour charge, gets you where you want to be.
      03-03-2011, 07:39 PM   #10
///M5Canuck
Yeah, I am leaning that way. Called and it would be about $55 to swap, probably worth it...then i can point to them if it is all messed up. Cheers.
      03-03-2011, 08:13 PM   #11
bmwarchitect
Drives: 03 BMW X5
......and if you run into walls, you will want it to work.
      03-04-2011, 02:08 PM   #12
jeffhoff
Drives: 2012 Alpine White X5 5.0
exactly what I was thinking when I saw the thread
      03-05-2011, 02:20 AM   #13
EV0LVE
EV0LVE's Avatar
24
Drives: F10 535i SG
$55 to swap airbags sounds a lot cheaper than reasonable, take it to the dealer.
