2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications The hunt for 11 secs F10 550xi
      03-11-2014, 02:29 PM   #177
badblack550xi
badblack550xi's Avatar
Originally Posted by rborgia View Post
At first glance, yeah... and 10th... the directions aren't totally clear. After spending another 10 minutes stopping and starting the video and tracing wires from the screen, this is what I came up with... am I even close? Now, if this is correct, what do we do with the cable/pin that is located in the DB25 position 1?
just do 2 day shipping to terry via USPS $6 and he will send it back same way.... unless you like the challenge.
2011 550i RWD 60-130 7.35
      03-11-2014, 05:17 PM   #178
aclockwrk
Drives: '15 M3 6spd
The Good news!
I finally had a chance to install the Stage 2 BMS tune. If you take your time and double check all connections if you're a little bit technically inclined its pretty simple.
Took a quick 5 minute test drive. No comparison to stage 1 even with bumping up the boost on stage 1. I'll run it as is for now and then experiment with bumping up the boost or checking any available maps. BTW, what maps are available on stage 2? I haven't checked yet. Also, any recommendations for bumping up the boost on
93 octane
93 Octane plus NOS octane boost
93 octone plus race gas
Now the bad news,
the wiring harness that goes to the TMAP sensors is way too short so there is no way to place the BMS box on the passenger side under that plastic cover as noted in the video. I used to have it on the drivers side and it reached with no issue. Since we are now tapping into the ECU i see why it needs to go on the passenger side, but the wires are no where near long enough to route it there. I need to secure it somehow and I worry about water. Can I get a longer harness?
Thanks,
      03-11-2014, 07:06 PM   #179
badblack550xi
Originally Posted by aclockwrk View Post
The Good news!
93 octane
Now the bad news,
Thanks,
post pics of how it looks.
      03-11-2014, 07:54 PM   #180
aclockwrk
Drives: '15 M3 6spd
I fixed it thanks to Terry. I didn't realize that the TMAP sensors needed to be swapped for Stage 2. I had installed stage 1 and routed the BMS box to the Drivers side. Swapping the TMAP sensors so the rainbow wired one is now on the passenger side corrected the issue with routing the BMS box on the passenger side.
BadBlack, how is your stage 2 running. Have you changed maps or raised boost. Results?
I can't wait to swap out my winter tires and hit the track again. Stage 2 the way it is, is a big difference over stage 1, I can only imagine what tweaking the settings will do.
      03-11-2014, 08:15 PM   #181
scott135i
scott135i's Avatar
Drives: 2020 X5 M50i
The TMAPs don't need to be swapped but its highly suggested! If you don't swap you have nearly no slack. I had my running for 2 weeks not swapped and once swapped I had so much more soon.
BBlack and my stage 2 both running great. We have changed boost settings with some benefits on better gas (100/105 octane).
Stage 2 is amazing. Running on race gas is better but even on 93 its incredibly better than stage 1.
      03-12-2014, 01:02 PM   #182
badblack550xi
I have a new goal to set in 2014 that is 11.7!!!!
      03-12-2014, 01:48 PM   #183
Alan l.
Alan l.'s Avatar
5415
sub 20lb wheels with drag slicks
pure race gas
some weight reduction
intake scoops
seems doable....
      03-12-2014, 02:03 PM   #184
scott135i
scott135i's Avatar
For sure...wheels alone should help cut a 1.6 60ft. With that running 11.9s, then 11.7s are possible easily.
Sergey will do it. He has nothing else better to do.
      03-12-2014, 02:07 PM   #185
badblack550xi
      03-12-2014, 02:09 PM   #186
badblack550xi
pure race gas
intake scoops
seems doable....
im doing it with M5 wheels and no slicks so later there is no crying that i was not on street set up.
      03-12-2014, 03:00 PM   #187
ARC550
Drives: M3, X5, 720s, X5, 750xi
do it on 93 octane.
      03-12-2014, 05:32 PM   #188
badblack550xi
Originally Posted by ARadoncic550 View Post
do it on 93 octane.
ok dad
      03-13-2014, 02:28 PM   #189
ARC550
http://www.dragtimes.com/BMW-135i-Timeslip-26291.html
check it out lol
      03-13-2014, 02:49 PM   #190
badblack550xi
Light car not impressed
      03-13-2014, 02:57 PM   #191
scott135i
scott135i's Avatar
I ran 11.61 in my 135i... I'll find the slip
      03-14-2014, 10:39 AM   #192
ARC550
That is awesome! id love to see the slip. The link i posted was with a Tune only. that is hella impressive. Those 135s are nice.. but small.
