2010 2011 BMW 5 Series Forum F10 BMS Stage 1 Check Engine Light (n63) |
10-22-2015, 09:25 PM | #67 |
Rep 738
I have stage 1, but my box says N63-2, Im running 2.75 on 93 with no issues.
Maybe its 3.0, I gotta check.
2011 550i
2013 M5 2014 M5 CP 2016 550i |
10-23-2015, 02:17 AM | #68 | |
Rep 736
What does the future use setting do ? |
10-23-2015, 09:57 AM | #69 |
Rep 844
Have you verified that with data logging? Ive found that most people don't even know what detonation sounds like, nor understand the damage it does to an engine.
2014 M5 Competition with ESS Tuning Flash
Gone but never forgotten...2015 X5 50i M Sport, 2015 550i M-Sport, 2015 M3, 2014 X5 50i M Sport, 2015 435i M Sport, 2011 550i, 2011 535i |
12-07-2016, 10:39 AM | #70 | |
Rep 659
12-07-2016, 10:42 AM | #71 | |
Rep 659
"If you have the current version of the BMS JB Stage 1 tuner for the N63 (G3_V2 board w/latest firmware) the factory default boost setting is already +3.0 (not +2.25). You can go a little higher with race gas mix (say, to +3.5), but the tune at +3.0 is already quite strong." Last edited by 535_BiTurbo; 12-08-2016 at 10:59 AM.. |
12-28-2016, 02:12 AM | #72 | |
Rep 736
i have the older one bms that suggests 2.25. So I should have no issues if I bump it up to 3.0? |
12-28-2016, 09:25 AM | #73 |
Rep 738
Email BMS, say your feeling it a bit rough, or something, and they should send you a replacement with the new motherboard (n63-2)
2011 550i
12-28-2016, 09:41 PM | #74 | |
Rep 736
Ive got catless downpipes, badblacks intake and an exhaust. What is the highest i can set the boost over stock without running any race gas? |
12-29-2016, 11:44 AM | #75 | |
Joint Chiefs of Staff
4908
Rep 115,980
Mike |
12-29-2016, 11:46 AM | #76 | |
Rep 738
Before they would send you the Stage 2 box instead. I think for 75$ to upgrade to the JB4 will be good because you can run more boost and have more options in case you would like to run race gas
2011 550i
12-30-2016, 09:51 PM | #77 | |
Rep 736
12-30-2016, 09:53 PM | #78 |
Rep 736
It turned out a couple settings on my bms stage 1 were not correct. Stage 1 had me at 2.25 lbs , how much higher can i go without running race gas? Plan on asking terry these questions too but thought I'd hear what you guys have to say as well. Thanks
12-30-2016, 11:46 PM | #79 |
Rep 1,399
I have mine set to 3 and I have crap California 91. When I run a race gas blend sometimes I bump it up to 3.5, you will be good on 3.
12-31-2016, 12:05 PM | #80 | |
Rep 738
Map 2: 6psi over stock additive I run Map 2 on 93 octane http://www.n54tech.com/forums/showthread.php?t=40626
2011 550i
