04-10-2012, 07:35 PM | #1 |
Rep 153
Idrive Reset
I'm posting this because I was searching for a solution and couldn't find it. I fixed it by accident so I'm posting it in case anyone has the same issue.
I brought my 2011 550i in for annual service. When I received it back, the idrive selection feature didn't work. I could scroll through the first page of menu options but couldn't select anything. I tried holding the eject button and radio power button in at the same time with no result. I disconnected the negative on the battery with no result other than erasing the time. Finally, for some reason, I held down the idrive knob while simultaneously pressing the eject button and radio power button. Now the idrive selection feature works(pushing down on idrive knob to select menu options). |
04-10-2012, 08:24 PM | #2 |
Rep 1,793
Drives: 06' E90 330, 20' F97 X3m
Hope I never have to use it but thanks for the heads up
LIVE FAST..DRIVE FASTER!! |
04-10-2012, 08:24 PM | #3 |
Rep 231
I know E90 had to press eject+radio power for reset, but this didnt work on F10. If you press radio power alone for 10sec+, idrive itself will reboot.
04-11-2012, 09:20 AM | #4 |
Rep 10,185
On the older CCC like in early E90 it was "Eject+Power button" to reset
On the newer CIC ( like F10, E90 LCI and F30) its "Hold down the Volume(power) button for 25 Seconds" to reset the system
BMW if you are reading, I need a job, Please. |
