2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Occasional shudder when shifting into Park?
      07-01-2017, 10:09 AM   #1
Breach
Drives: F10 520dA M Sport
On a couple of occasions already I've noticed that putting the car in 'P' would cause quite a palpable shudder (like going over a bump). Shifting into 'D', 'N', 'R' is OK, no transmission slippage either... It doesn't happen often but does happen. Any ideas? It could be 'normal' but I don't recall this happening before. Thanks.
      07-02-2017, 12:02 PM   #2
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
The only time I would see that happening is if the car was still slightly moving as you press the P button. Which in that is very bad for the transmission in the long run.
      07-02-2017, 12:09 PM   #3
Breach
Of course, but not the case - it happens with the brake pedal firmly depressed and the car fully stopped. Hence I suspect a mechanical issue.
Also checked with ISTA today - no fault codes.
