2010 2011 BMW 5 Series Forum F10 Retrofit M5 f10 cluster on 523i |
07-24-2019, 03:49 PM | #1 |
Rep 5
Hi guys
i just want to ask if anyone can help me to retrofit a m5 cluster to my car and help me with the coding or give me instructions on how to code it like this one on the photo is it possible like this guy just did https://www.bimmerfest.com/forums/sh...d.php?t=786565 Thanks in advance |
07-26-2019, 09:18 AM | #3 |
Rep 133
07-26-2019, 02:51 PM | #4 |
Rep 5
07-26-2019, 07:29 PM | #5 | |
Rep 61
I have both M5 and N20. I did HUD, Shifter and Cluster. I spent like 4 months to figure out. These are the pictures[IMG][/IMG] |
07-27-2019, 12:12 AM | #6 | ||
Rep 590
07-27-2019, 01:11 AM | #7 | ||
Rep 133
07-27-2019, 09:17 PM | #8 |
Rep 61
07-27-2019, 09:18 PM | #9 |
Rep 61
11-11-2021, 07:02 AM | #10 |
Tinkerer
83
Rep 532
Sorry to resurect and old thread.
bmwf10projects any chance you could share the love mate? I have an f25 (2tm 8speed sport tranny) and can pick up an m6 kombi up cheap, any help on how you did this would be great.
2014 F25 X3 335d M-Sport:
03-17-2023, 12:17 PM | #12 |
Rep 2,593
Notice how their photo shows no gear. This is because it is not possible to get gear information on a non-M5 car, as the gear information comes from an entirely different ECU that non-M5 cars don't even have.
2015 BMW 535xi
03-17-2023, 06:13 PM | #13 |
Rep 234
I am working on this as we speak, waiting for some harness pigtails to come in to connect additional wires to icm and dme, &dme2.
The problem is not the cluster itself as the wiring to it is the same across the board, it’s the gear shifter and dynamic control board that has to be rewired. I’ve done a lot of research on this and looked at wiring more then I’d like to admit, M5 Cluster is not enough for a fully functioning retrofit. This is where most make a mistake trying to get the cluster to work with some random coding in E-Sue to hide gear shift errors, etc. will make a post or reply here once I’m done as most people who have tried have either failed or do not respond. There is a YouTube video of a guy from overseas retrofitting gear shifter and controls but he’s using 6WB cluster not M5 one so no issues there. I don’t see the point of this really without the cluster, but to each their own. |
03-17-2023, 08:51 PM | #14 | |
Rep 2,593
2015 BMW 535xi
06-05-2023, 04:44 PM | #18 |
Rep 49
Drives: 2015 535i xDrive
Thinking about doing this. To anyone who has successfully done this retrofit, please let me know what needs to be coded because I assume its not just PNP.
04-06-2024, 02:54 PM | #20 |
Rep 4
slobo7x
hi, the video is no longer valid, can you give me some details on how to get my gears to appear on the dashboard? I too have a F13 640i and have M6 cluster . Thanks |
04-06-2024, 04:28 PM | #21 |
Rep 234
You cannot code gears into the cluster to show up, I’ve done extensive work and research and we just don’t have the hardware on non-M models to make that happen.
This requires a physical hardware adapter to get to work. Do a search on f30 m3/m4 cluster adapter and that’s what you need, it’s about $350. Good luck |
GabiSibiu0.00 |
