2010 2011 BMW 5 Series Forum F10 Bavsound Ghost underseat subwoofer 2 ohm |
11-27-2023, 05:56 PM | #1 |
Rep 31
Selling a pair of gently used Bavsound Ghost underseat subwoofer 2 ohms. Make sure you check on the bavsound.com to see if your stereo takes the 8-ohm or 2-ohm. Complete in box with original packaging. Will ship for whatever UPS charges. Nice sound upgrade. |
11-29-2023, 07:41 AM | #2 |
Rep 505
Drives: 2013 BMW F10 N55 535i XDrive
car just flooded, might be getting these from ya, how do I check if these are the correct ohms for my car?
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
11-29-2023, 02:32 PM | #3 |
Rep 2,591
They're plug and play for the F10, so no concerns regarding ohms.
2015 BMW 535xi
musclesmarinara75206.00 |
11-29-2023, 02:51 PM | #4 |
Rep 505
..My man, thanks Jeff... so you saying pull the trigger?
11-29-2023, 05:35 PM | #5 |
Rep 63
There are two versions of these upgraded woofers, an 8ohm and 2ohm both of which are plug and play
These will work if your have the HIFI standard system S676A. If you have the Harmon Kardon, (S688A) or the logic 7 (S677A) then you need the 8ohm version. |
11-29-2023, 06:51 PM | #6 |
Rep 505
Yeah, I researched that, I have the standard hifi
12-04-2023, 12:27 PM | #7 |
Rep 31
This is correct. HIFI standard uses the 2-ohm. Also bavsound.com can confirm this. Still have these.
12-30-2023, 10:48 AM | #9 | |
Rep 167
What happens if I don't install dynamat? is it just around the speaker install or the whole panel? in this case the entire subfloor? |
12-31-2023, 06:54 AM | #10 | |
Rep 38
What happens if I don't install dynamat? is it just around the speaker install or the whole panel? in this case the entire subfloor? You can get a whole detailed audiophile answer but in short adding dynamat helps improve the sound quality of audio, louder bass etc you don’t need it by any means just something good to do if you want the most from your audio experience. |
12-31-2023, 11:48 AM | #11 |
Rep 167
Thanks !
01-01-2024, 04:12 PM | #12 |
Rep 31
I don’t think you need to dynamat. The bottom of these have a rubber liner that sit snug in the socket. I had 0 rattle ever even turned up.
