2010 2011 BMW 5 Series Forum F10 Still leaking oil after valve cover gasket replacement? Lots of white smoke |
02-29-2024, 12:35 PM | #1 |
Rep 6
Hi my car has been visibly leaking oil even after a valve cover gasket replacement the smoke is substantial especially after it heats up, any advice on how to handle this situation? I've been trying to resolve this issue for months now. Lots of time and money spent and no resolution. It's not covered by warranty either whatever the problem is.
02-29-2024, 01:58 PM | #2 | |
Rep 505
Drives: 2013 BMW F10 N55 535i XDrive
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
Conserve186.00 stephybimmer1.50 |
02-29-2024, 02:29 PM | #3 |
Rep 5,378
ChiltiCoatl891775.00 |
02-29-2024, 08:36 PM | #4 |
Rep 127
1). Valve cover has tendency to crack on high mileage cars due heat cycles.
2). As said above, may not be installed correctly. 3). take that beauty cover off and show where exactly is leaking point(s) |
02-29-2024, 08:38 PM | #5 |
Rep 436
Drives: 2016 F10 BMW 535i M Sport
As mentioned above, Valve cover needs to be inspected as well as installation of the valve cover and gasket.
02-29-2024, 08:57 PM | #7 |
Rep 6
I tried liquid moly motor oil saver also to see if it will help cause this is ridiculous I hope it works. They kept saying the oil will burn off well it never stopped becasue it still leaking and I didn't notice becasue it was snowing.
02-29-2024, 08:59 PM | #8 |
Rep 436
stephybimmer1.50 |
02-29-2024, 09:02 PM | #9 |
Rep 436
Make sure you read the reviews of the shop, make sure they are good at what they do from others first before pulling in. Research your choices because last thing you want is more $$ down the drain for a shabby job.
stephybimmer1.50 |
02-29-2024, 09:07 PM | #11 |
Rep 436
stephybimmer1.50 StradaRedlands4964.00 |
03-01-2024, 09:27 AM | #12 |
64-bit
598
Rep 817
Drives: 2018 BMW 340i xDrive
What a coincidence.. I just had my valve cover replaced including all of the gaskets for my 2016 528i xDrive currently at 159,000 miles. Attaching the receipt here as well.
2 days later I noticed a huge oil leak from the passenger side. Attached photos as well. Took it back to the trusted shop and they diagnosed it and noticed the oil leak was coming from the Camshaft Variable Valve Timing Solenoid Gasket. Attached a photo of where this sensor is. What they think happened is either the gasket seal had gone bad and/or the technician put too much force when putting the sensor back on to the Valve Cover. Hope this helps but I would check your just to he safe. |
stephybimmer1.50 |
03-01-2024, 02:06 PM | #13 |
Rep 6
Oh geez these cars love to leak huh? I have the same car so I guess we're in the same boat, thanks for the info! The weathers getting hot and I worry because warranty told me it's a fire hazard but still won't cover it. Lol
ErkanTR16598.00 |
03-01-2024, 09:18 PM | #14 | |
Rep 436
ErkanTR16598.00 |
03-08-2024, 09:31 AM | #15 |
Rep 505
If you are still leaking at this point you need to change that valve cover from what it sounds like, where are you located?..I know it stinks, but lesson learned and NEVER NEVER NEVER go to the dealership!!.. maybe go there for the free snacks... then leave!
StradaRedlands4964.00 M_Bimmer588.00 |
03-08-2024, 08:01 PM | #16 | |
Rep 3,033
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
Always grab a couple of those! Last edited by StradaRedlands; 03-09-2024 at 11:17 AM.. |
ChiltiCoatl891775.00 musclesmarinara75206.00 |
03-11-2024, 06:56 AM | #17 |
Rep 505
Yup!!... forgot about those little grenade bottles
