2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK 520d vs 525d
      11-22-2014, 05:17 AM   #1
CraigUK
Drives: F11 LCI 520D Sport Tourer
520d vs 525d
Just a quick post to ask if anyone has taken the time to research what if any hardware differences there are between the 520d and 525d, presumably it's more than just a different engine map?
      11-22-2014, 06:36 AM   #2
The Beast
The Beast's Avatar
Drives: VW Transporter Sportline
I'm pretty sure that the 525 is a twin turbo
Current: VW Transporter Sportline, F48 X1 20i M Sport. Previous: F10 530d M Sport, W176 A200 CDI AMG Evolution, E70 X5 3.0 SD M Sport, F20 120d M Sport, E81 120d M Sport, E46 325i M Sport, E46 318ci & Many Others...
      11-22-2014, 06:47 AM   #3
Hobbe74
Hobbe74's Avatar
Sweden
15
Drives: F10 on order
Both are twin scroll but not twin turbo. Id go for the 520d and a tuning box.
      11-22-2014, 06:56 AM   #4
HighlandPete
Drives: BMW F11 535i Touring
If we are talking about the N series engines we have a single VNT/VGT turbo on the 520d and sequential bi-turbos on the 525d.
Turbo setups like comparing a 530d to a 535d.
HighlandPete
      11-22-2014, 10:40 AM   #5
CraigUK
Thanks all, for some reason I was thinking that they both have twin scroll turbos.
The reason I asked is that I noticed both Hartge and Steinbauer are both quoting outputs comparable to a standard 525D from their tuning boxes.
      11-22-2014, 01:26 PM   #6
ZeroFx
Drives: M4x
Yes you can also tune the 525 though
      11-22-2014, 05:17 PM   #7
gspannu
Drives: F10 535, F82 M4
HighlandPete
Absolutely correct, thanks Highland Pete.
BMW's naming conventions or their terminology (twin scroll, twin turbo, etc...) does not really make it easy to understand any of this !
      11-22-2014, 05:41 PM   #8
HighlandPete
Particularly as twin scroll is now often confusing used, (but only applies to the petrol engines) and Twin Power on engine covers, even for single turbo diesel engines.
Twin Power means different things for different engine types according to BMW blurb.
HighlandPete
      11-24-2014, 07:11 AM   #9
Hobbe74
Hobbe74's Avatar
Sweden
15
HighlandPete
Thanks a lot for that input!
It's rather confusing in the tech spec:
They use the term twin power turbo engine with variable turbine geometry for the 520d and twin power turbo engine and two-stage turbocharger with variable turbine geometry for the 525d...
Not all that clear that it is two turbos so thanks again.
      11-24-2014, 02:46 PM   #10
makkan00
makkan00's Avatar
Drives: F83 and F36
Is pre-LCI 330d twin turbo as well?
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      11-24-2014, 03:04 PM   #11
HighlandPete
No single VHT/VGT turbo, the 335d was sequential bi-turbos.
HighlandPete
      11-24-2014, 03:12 PM   #12
makkan00
makkan00's Avatar
Drives: F83 and F36
HighlandPete
HighlandPete
Sorry. Just to clarify
Pre-LCI 525/530d is single turbo like 325/330d.
LCI 525/530d is twin turbos like 335d? (if twin turbo = sequential bi-turbos)
Are they not n57 engines if you are referring 'N' to N57 engines?
      11-24-2014, 03:16 PM   #13
CraigUK
The latest 525D is a 4 pot with two turbos where as the old 525d was a 6 pot motor with one turbo. The 530d has one turbo too.
      11-24-2014, 03:31 PM   #14
HighlandPete
4-cylinder engines are N47 variants, the 525d being an N47S1. 6-cylinder are N57 variants. To confuse it all, latest 520d is a B series engine.
HighlandPete
      11-25-2014, 01:14 AM   #15
makkan00
makkan00's Avatar
Drives: F83 and F36
Make perfect sense now except B engines
