2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK 535D 313hp more power needed, remapping, chip box, anyone done it in the UK?
      05-14-2015, 01:40 PM   #23
ianF10
ianF10's Avatar
Drives: 535d M-Sport F10
Yes I agree, it took me a while to identify the boost sensor.
I'm now running map 6 of 7 and have had no problems or faults so far and am so impressed with the performance, it has transformed a great car into a fantastic and best of all fun car to drive.
I'll try the gearbox reset although I have no complaints.
      05-14-2015, 01:48 PM   #24
F36 435d
F36 435d's Avatar
Drives: Individual Speed Yellow 435d M
I imagine that the DTUK and Tdi Tuning boxes are very similar. Yes if you reset the gearbox it will 'adapt' to how you drive. If after you reset it and you drive quite quickly, you will notice that the car will feel and respond slightly quicker. Its nothing to loose out on.
      05-16-2015, 02:26 PM   #25
texasjohn
texasjohn's Avatar
Well done, nice mod. I have purchased a BMS tuning box for the 550i. I fitted it and it made quite a difference. I have taken it off again though because I'm messing about with exhausts at the moment (another story).
F10 M5 CP.
Previous: F31 340i, E90 335i SE, E87 130i, F10 550i, E92 335i, E61 550i, E90 335iM, E87 130i, E87 118d, Z4M, Z4 3.0i SMG, E46 330D, Z3M, Z3 3.0i, Z3 3.0i (USDM)
      05-25-2015, 06:14 PM   #26
Peiper
Romania
21
Drives: 535d
Hi,
I had 2 boxes one from Racechip.com and one from http://www.tuningbox.com/ and I was disappointing with both of them. With the first the acceleration was not linear and the second gave some errors.
I had the same message of drive train error which resulted in changing the electrovalves of the turbos so be careful. I think the remap is the way to go.
      06-03-2015, 03:10 PM   #27
F36 435d
F36 435d's Avatar
I have spotted a DTUK tuning box for sale on ebay for the 313ps Bmws.
eBay item number:131514408240
I have no connection with the seller, just pointing out a good deal for anybody who is thinking of getting one.
      06-15-2015, 04:11 PM   #28
OEMonsterz
OEMonsterz's Avatar
Drives: 535D M Sport
ianF10 Where are you based in Essex?
I have a racehip installed on my 535d M Sport and definitely agree it's the best way to go, especially if you have a warranty.
Be careful as you can throw the check lights when you crank it up!
      06-16-2015, 04:16 PM   #29
F36 435d
F36 435d's Avatar
Are the Engine Management lights recorded on the ECU so if it goes back for warranty work they will be able to see it ?
The best map for the DTUK on the 535d 313ps is 3+1. It is the smoothest and you will not get any engine lights.
      06-18-2015, 05:24 AM   #30
ianF10
ianF10's Avatar
Hi OEMonsterz.
I am near Southend-On-Sea.
As previously stated I am running map 6 of 7 so nearly full power and it has been faultless, no errors or alarms. I would like to put it up to 7 but as its running so nice am reluctant to change it.
      06-28-2015, 03:25 PM   #31
OEMonsterz
OEMonsterz's Avatar
Yes, be careful if you have a warranty with BMW!!!
Anything and everything throws a check control error and gets registered in the log. I know from bad experience!
Basically I installed the chip as is (purchased used from an F10 530D owner, who had cranked the settings to a nutter level) and everything was fine until one day I tried to gun the car from a standstill. Suddenly malfunction came up (SHAT MYSELF) and the car cut off... booked it in for a check at BMW Elms Stortford ASAP. They confirmed it was an error that had just happened and it was highly likely to do with the chip.
During the diagnostic they told me of every single MINOR error, including the time and dates I replaced the interior lighting.
If you are going to do mods, bear this in mind if you have a warranty with BMW Direct! You will need someone with a PROPER DIAGNOSTIC kit to clear the errors, otherwise BMW will have you over a barrell.
I hope this helps you and anyone else!
      06-28-2015, 03:54 PM   #32
OEMonsterz
OEMonsterz's Avatar
Originally Posted by ianF10 View Post
Hi OEMonsterz.
I would leave as is then. As they say, if it ain't broke ..don't fix it
I am near Romford.
      06-29-2015, 04:11 PM   #33
Tengocity
Tengocity's Avatar
Scotland
8567
Drives: 911, Cayenne Turbo, Disco 4
If it's of any interest my 335d has been remapped by DMS and I asked them to limit the torque to 700nm.
The UK 3 series forum had a dyno meet meet last week and the runs there confirmed that this was what my car put out, alongside 360bhp.
They can do more if you want, as can ecotune, as the car done by them was up at 385bhp and about 740NM.
The cars running tuning boxes had mixed results with either weaker figures than advertised and a lack of smoothness/consistency between runs.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
      07-21-2015, 01:59 PM   #34
silo24
Drives: F10 LCI 535d
Just to add a another option for those that wish to pursue the Tuning Box route:
I used Spider Tuning whose system is a 3-channel unit, meaning Common Rail, Boost and MAF and have had great results. The purported numbers are frankly a little ridiculous (313PS to 414PS and 630Nm to 740Nm) however I do believe it is somewhere near 380 and 700Nm as the grunt is truly epic!
Strangely (and I would be interested if this is noticed by other 'Box owners), the car runs smoother and quieter than stock.
Latest units are quite interesting as they have released a Bluetooth controllable unit so you can change maps without getting under the bonnet.
http://www.dieseltuning.co.uk/store/...product_id=293
F10 LCI 535d (313PS) M Sport
      07-27-2015, 05:05 PM   #35
F36 435d
F36 435d's Avatar
Does anybody see any benefit using high octane fuel for example Shell V Power 99 Over regular for example 95 Tesco Diesel with a tuning box fitted or with a remap?
I have a DTUK on my 535d 313ps and it is 2 years old and has done 22,000 miles. Im just wondering whether i should remove the tuning box and sell it and get it remapped to 360 bhp & 700nm or just keep the tuning box on.
Thanks
      07-30-2015, 07:18 AM   #36
The Beast
The Beast's Avatar
Drives: VW Transporter Sportline
This is an interesting box, really like the idea of being able to adjust it from inside the car. I just had a chat with their technical support team and you just download an app and can then control the unit. Think I may take the plunge and order this box...
      08-06-2015, 10:36 AM   #37
DriftProjectR
Drives: 135i
I'm considering the Spider Performance System for my 535D. Anyone feel that there is a better product on the market?
2014 BMW 535D Black Saphire
2008 BMW 135i Alpine White
      07-18-2018, 10:58 AM   #38
Cabamaru
Drives: BMW F11 535D LCI
Tuning options
Hi everyone,
I recently bought an F11 535D LCI and although it is plenty fast for now, from reading around in forums it seems so easy (and safe?) to gain a significant amount of performance, that I have started looking about tuning options.
This thread is quite old, but I see that as a good thing as tuning options will have been tested thoroughly by now.
I would greatly appreciate some insight regarding the different options.
Reading this thread, the systems that seem to be more recommended are:
1. TDI Tuning
2. DT-UK
3. Spider (DieselTuning)
Can anyone recommend one over the others for any particular reasons?
Also I read in other threads/forums that ECU remaps, tend to be better. Is that still the case or have the aforementioned tuning boxes improved to the point that they are equally good?
Many thanks in advance!
      07-19-2018, 01:34 AM   #39
bfleming
Drives: Merc, VW, Porsche, Suzuki
This thread is indeed old, and remaps no longer necessitate the removal of the ECU - new technology means they can be done over the OBD2 port.
We all have our tuner of choice; my favourite is Birmingham based EndTuning.com, the guy is a wizard!
Audi A4 Quattro 2.0TDI 177 2012/12
VW Golf GTE Advance 2017/67
Porsche Boxster 986 2.7 2000/X
Suzuki GSXR 750 2004/04
      07-19-2018, 04:01 AM   #40
Cabamaru
Thanks for your input.
Do you have a view on whether remapping the ECU is better than the various tuning boxes? I do appreciate the convenience of being able to install/remove as I please, and I guess the selection of different settings for MPG vs performance as long as they are not significantly worse that the remaps.
      07-19-2018, 05:17 AM   #41
bfleming
I've done both over the years, and a good remap on a reliable & well maintained vehicle is my preference. Tuning boxes are more basic, although the Racechips ones are pretty good (I ran one on my 320d N47). It's horses for courses.
If you have an accident, an insurance company is highly unlikely to uncover a remap - whereas a tuning box will stick out like a sore thumb. I do hope this isn't going to turn into an ethical debate about declaring mods.
If your car is still under warranty, and/or you bring it to BMW for servicing, your remap can disappear if BMW do software mods. Likewise if there's 'rogue' software found on the ECU, BMW may not cover warranty claims.
      07-19-2018, 11:11 AM   #42
Cabamaru
Car is not under warranty so that is not an issue. Regarding accidents, assuming the mod is not declared, my initial thought was that a tuning box is preferable because it can be removed, but thinking more about it that depends on the severity of the accident.
Thanks for your insight.
      11-15-2018, 04:58 AM   #43
xpro
Drives: 335XD
I've had both initially, and I used my friends tunning box just to try it out before the remap. Essentially all they do is alter the fuel ratio as the tuning box plugs in between the injector rail.
Got my old 535d remapped afterwards , car ran so much better, not even worth comparing it to a tuning box.
      11-19-2018, 05:48 AM   #44
JOHNBMWM5
JOHNBMWM5's Avatar
Drives: 2022 LCI Marina Bay Blue/ Smok
Originally Posted by Piers View Post
Tony at DMS Automotive tells me he can get a 520d to 250bhp undetectably, so I am guessing he can sort a 535d too...
He's bullshiting.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
