2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK 520D with 535 style dual exhaust
      10-11-2015, 08:13 PM   #1
eliw
Drives: F25 X3 2012
How hard is it to retrofit the 535 dual exhaust (one tail pipe on each side) to an F10 LCI M sport 520D ..
I understand the 535 diffuser is easily obtainable and should fit any M sport F10 but whats the best and cheapest way to obtain the exhaust and is it a plug and play procedure to install it on the 520D? Any UK outfit does this ?
Good Looks is my goal - sound is not an issue so something that fits and looks as genuine as OEM is what i'm after.
Something similar to this but with OEM tail pipes :
      10-13-2015, 08:19 PM   #2
eliw
Drives: F25 X3 2012
Found a company called Mstyle in Romford that does the retrofit that I need exactly as described above http://www.mstyle.co.uk/f10-f11-535i...onversion.html
Has anyone had any dealings with them and would you recommend them if you did.
Thanks.
      10-14-2015, 07:41 AM   #3
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
Thanks.
i have bought some stuff for my mini off their website - no problems here, but not actually been to their work shop. they advertise in BMW Car magazine and are well known for their work with BMW and Minis.
2014 M5
1990 E30 318i Touring
1999 E38 728i -sold
M235i - sold
Activehybrid 5 - sold
      10-15-2015, 01:13 AM   #4
valbmw
valbmw's Avatar
94
Drives: 2016 BMW F10 M5 CP 600 hp
This is a simple project for any good exhaust shop and it consists of several steps.
First, you buy the OEM or aftermarket 535 or 550d exhaust at your choice. Second, the existing exhaust needs to be cut at the point of Y-pipe insertion. Third, the deep plastic box is removed from the right side of the trunk, the shield plate is installed, the short box from 535 / 550 is mounted. Fourth, thermo shield (2 pieces) is restored in the right muffler niche. Fifth, the OEM hangers restored to hold the right side. And sixth, the exhaust is installed with Y-pipe at the proper position, also the diffuser is added.
Done!
      10-16-2015, 05:02 AM   #5
eliw
Drives: F25 X3 2012
Where can I get an aftermarket exhaust from... And apart from the company above, do you know of any other company who does this conversion in the south East?
