01-21-2017, 08:09 AM | #1 |
Rep 582
530d Eco Pro Mode
Hi guys,
When I drive my 530d in Eco Pro Mode, it seems to absolutely love sitting at about 900-1000rpm. Which is fine, but when I apply any sort of throttle at this level of revs I get an annoying and intrusive resonating noise from what sounds like the exhaust or something. I suspect this is a 'feature' of the ridiculously low rpm rather than a fault as the car has done it since new. I'd always thought that driving along at this sort of RPM was a bad idea but as it's an automatic I have no real choice over it's decision to this. Anyone else find this? I'll get it mentioned at first service if not.
Current: 2021 M340i xDrive, 2001 530i Sport
Previous: 2015 530d M Sport, 2010 530d SE, 2008 335i M Sport |
01-21-2017, 11:05 AM | #3 |
Rep 582
Generally quite low speeds really - 0 to 30mph.
01-21-2017, 02:59 PM | #5 | |
Rep 15,858
We have a VW with DSG which is changing too early on light acceleration, horrible exhaust induced drone. I'm not convinced on all the Eco-Pro tuning. What's it like in Comfort mode? I guess it runs a few more revs and no issues. |
01-21-2017, 03:06 PM | #6 |
Rep 582
It's there when pulling away from, say, speed bumps in Comfort mode but generally the revs are sufficiently high that it isn't an issue.
But eco-pro sailing mode is really rather cool around town, and you don't get that in Comfort
01-21-2017, 03:20 PM | #7 |
Rep 15,858
There is the possibility remounting the exhaust (tweaking the positions of the mounting brackets) could eliminate it. Needs to be on a ramp and see if it is exhaust vibrations, by gently moving through the critical rev range.
01-21-2017, 05:42 PM | #8 |
Rep 225
Cannot comment on the 530d but on those occasions when I have used Eco Pro in my 535d (shorter final drive ratio to the 530) it's running at 1000-1100rpm. That's about 52 mph in 8th. IMO it is changing up too early. It makes it sound like my previous 520d....Rough.I assume to save fuel it is running off boost. I don't like it so I don't use it.
01-22-2017, 03:02 AM | #9 |
Rep 582
It does annoy me a bit how soon it changes up in anything other than sport mode.
The net result is that you either have a car that is a bit more sluggish than it otherwise ought to be, in Comfort, or a car that is hilariously powerful at all times in Sport mode. Sport seems like too much for normal driving.
