2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Fuel additive for N55
      03-21-2020, 11:28 AM   #1
zcali925
zcali925's Avatar
Drives: '15 BMW 535i M Sport
Looked at these but at only 50k on my 2015 I'm not sure I need to add anything yet. Getting ready to do spark plugs, ignition coils, brake warning will probably come on any day. Thinking about doing an 8at fluid change and update.
Sup
      03-21-2020, 01:30 PM   #2
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
Don't bother except for maybe injector cleaners, and even then it's questionable if it actually does anything.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      03-21-2020, 02:23 PM   #3
BurrNinja
I usually run shell 93 vpower every few fill ups ill add techron fuel cleaner.
Instgram @burninja
      03-21-2020, 04:44 PM   #4
zcali925
zcali925's Avatar
Thanks!
Sup
BurrNinja430.50
      03-21-2020, 04:45 PM   #5
zcali925
zcali925's Avatar
I only really have access to 91 in the bay area
Sup
BurrNinja430.50
      03-22-2020, 09:36 AM   #6
BurrNinja
Id run techron every few imo.
Instgram @burninja
      04-21-2020, 12:37 PM   #7
MOBF10
MOBF10's Avatar
171
Drives: 2018 M3 Comp
Money is probably better off spent on walnut blasting. If you have crazy build up on your intake valves you will notice immediate difference in your car after a good cleaning. FYI running meth will help keep them clean too
      04-21-2020, 08:41 PM   #8
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
I would wait till 70 to do trans fluid. I did mine at around 135 and fluid was still clean.
      04-30-2020, 12:32 PM   #9
ChiNorm
Drives: '13 535xi
I did mine at 66k and it made a BIG difference in transmission response.
      04-30-2020, 02:49 PM   #10
xxpanipuri
Drives: 550i
i do techron every so often and i'll do zmax as well...
where in the bay are you?
      05-05-2020, 09:02 AM   #11
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
I'm gonna start using Techron on every fill up! I don't daily drive the car and I now hope after adding the oil catch can this will help eliminate some of the blow by
      05-07-2020, 12:21 PM   #12
RJV3
Customize Everything!
Drives: 17 F06 Gran Coupe/ 16 F10 535
Which catch can did you end up getting? I saw a massive thread about catch cans but feedback on finding one that has a oem like fit was hit or miss. Either the tubes were too big or pain in the ass to install and run the lines effeciently.
      08-03-2020, 10:10 PM   #13
zcali925
zcali925's Avatar
East Bay. You?
Sup
      03-18-2024, 11:37 AM   #14
DemonSR
Drives: BMW 535i
No need for any fuel cleaners. Just run the highest grade of fuel at Irving, Mobil or Shell station. (Verified with BMW manufacturer)
