03-24-2024, 12:06 AM | #23 |
Rep 30
Hello folks!
Planning to DIY this project sometime soon. How high is the risk of coolant/oil contamination? I am planning to do oil change next day. But my coolant is fresh after water pump project I noticed that FCP suggests replacing all the bolts and oil sensor in their kit: https://www.fcpeuro.com/products/bmw...11428637821kt5 Yet, haven't really seen that many writeups/videos with all of the additional stuff. I was planning to replace the serpantine belt as well. What would you guys recommend? |
03-24-2024, 12:26 AM | #24 |
Rep 435
Drives: 2016 F10 BMW 535i M Sport
Check your belt tensioner and pulley(s), replace as necessary, be sure to check if you have adaptive drive or not as they are different belt sizes.
03-24-2024, 09:18 AM | #25 |
Rep 1,442
Drives: 2011 535i 6MT
100% replace the bolts. They are TTY (torque to yield). Meaning they stretch to do their job. Any and all aluminum bolts need to be replace once removed. Use a magnet if you are unsure of their composition.
03-24-2024, 09:33 AM | #26 | |
Rep 127
I would replace hardware on OFH but not on heat exchanger. Be mindful of what type of heat exchanger you have because the hardware for it are different. proper torquing of hardware is very important. replacing Mickey mouse coolant flange is recommended while you are in there. Oil priming is very critical for this job. Therefore remove fuel pump fuses, run the engine till it dies and then proceed to the task. https://f10.5post.com/forums/showthread.php?t=2086982 |
03-26-2024, 11:43 AM | #27 |
Rep 30
Thank you all for all the input!
So I think the flange is this item: https://www.fcpeuro.com/products/bmw...e-rein-chc0609 What do you guys think about Elring vs Mahle for gaskets? Also, I was thinking skipping replacement of Oil Pressure sensor and intake manifold gasket(does one need to be removed for this DIY?) |
03-26-2024, 12:10 PM | #28 |
Rep 1,442
That is it! Iirc you do have to remove the intake manifold. Gaskets… I have skipped replacing them in the past however for how cheap they are I would lean towards doing it. Other sensor can be skipped since you can replace it easily if need be.
03-26-2024, 12:54 PM | #29 | |
Rep 2,590
2015 BMW 535xi
