2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 2014 535i N55 PWG - Exhaust Drone HELP Please!
      10-10-2023, 10:09 AM   #1
bryanc21317
Drives: 2014 BMW 535i N55 PWG
Hey,
Newbie here to the forums. Thanks for the help in advance.
i have a 2014 BMW 535i n55 PWG, MHD Stage 2 tune. Custom made Catted Down pipe, vsrf charge pipe/upper and lower, vsrf 7.5 inch intercooler, k and n drop in filter.
Recently I went to have the exhaust changed, they cut out the stock mufflers and added in Borla S type, which sound amazing. The issue I am having is between 1500 and 2300 rpms I have a horrible interior drone.
The Frequency is right around 104hz at 67db, so it is quite loud and annoying.
I took it back to the muffler shop and had them add 2 - Vibrant 12 inch Resonators model 1792 Bottle Style resonators yesterday, same thing. No Change.
I have these quad tips they also added, to make it look more aggressive in the rear.
https://www.amazon.com/BLACKHORSE-RA...a-643473555003
Can anyone tell me if the tips are not sticking out far enough? Any ideas on what MAY be causing the Drone?
I love the sound, but I can not deal with the Drone inside the car, so that will be a deal breaker for me.
Thanks for any help you can give me!
      10-11-2023, 10:51 AM   #2
Hoa
Drone is common when you change both dp and exhaust. You will have to revert one of them to get rid of the drone
      10-11-2023, 11:32 AM   #3
bryanc21317
So your saying there is no way to have the Catted Down pipe and the Borla S Type Mufflers without the drone?
What about adding a J Pipe?
Also, My muffler shop is telling me to drive it 1000 miles until the mufflers break in, has anyone ever heard of this?
Thanks in advance!
      10-11-2023, 01:31 PM   #4
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
A j pipe (otherwise known as a quarter wave resonator) should cancel out that specific frequency. Based on this article's calculator, a 104hz drone should be cancelled out by a 32-33inch J pipe.
2015 BMW 535xi
ISTA VM Setup/Tutorial
