2010 2011 BMW 5 Series Forum F10 clunk sound after lowering car with H&R springs |
09-15-2015, 01:36 AM | #1 |
Rep 99
Installed H&R springs this past weekend, got about 1.25 inches lower all around, just what i wanted. But not hearing a mild clunk sound from drivers front side when going over very small bumps at very slow speeds, im talking less than 5mph and like a crack in the road, going faster or cornering is all good.
Any ideas what the issue could be here? Dont think i missed anything while installing them. The car is a 550i |
09-16-2015, 04:42 AM | #4 |
Rep 540
did you do it by yourself? maybe we can check when I come back from my country. I live in Seattle. let me know if you want to meet up and check if the spring is right or not.
09-16-2015, 02:58 PM | #5 |
Rep 14,522
Yeah I would double check your install cause normally improper installs will give u noise, clunks and all kinds of weird sounds if not done right.
09-16-2015, 03:08 PM | #6 |
Rep 99
Yeah did the rear ones with a buddy and the fronts on my own. I'll let you know in the next few days, i think I'll take the side apart tonight and re-do everything and see if it goes away. I have a feeling the spring isnt seated right, still cant believe i messed up like that.
09-17-2015, 12:24 AM | #7 |
Rep 99
Checked it out tonight, everything looks good, there was a loose plastic peice near the sway bar, which wasnt the issue. Upon further investigating, its something to do with the braking system, when the car is moving like 1mph and every time you apply the beakes, even litely, it mskes the sound. Like the brakes pads are loose and are moving around. Not sure how thats related to the springs, but thats what it sounds like and thats where the noise is coming from...
09-17-2015, 07:12 AM | #8 |
Rep 738
weird, I did my coilovers all by myself and didnt have a problem except i left the sway bar a bit loose, i was about to cry thinking I fucked something up lol
Maybe you loosened something around the brake area by mistake ? check all bolts
2011 550i
2013 M5 2014 M5 CP 2016 550i |
09-18-2015, 01:58 AM | #10 |
Rep 540
https://www.facebook.com/isgaragellc. I changed my spring here, probably you can ask them the problem.
09-18-2015, 09:46 AM | #11 | |
Rep 687
Because the shock can turn sometimes you may not tighten it all the way. |
09-27-2015, 02:03 AM | #13 |
Rep 99
03-15-2016, 12:26 AM | #14 |
Rep 438
Drives: F10 535i MSport, F15 X5 MSport
Any conclusion on this? I run kwv3 coils and hadn't had any issues at all until recently I started hearing clunks. Dealer told me my sway bar was bent so I ordered the M5 sway bar mod to go thicker and had that replaced but the clunk is still present. Ugh.
03-17-2016, 09:50 AM | #15 |
Dream crusher
983
Rep 2,421
Are the shocks blown?
IG: @bmwdoubles |
