2010 2011 BMW 5 Series Forum F10 Refill tank before it's three fourths empty |
06-29-2015, 09:46 AM | #67 |
Rep 1,812
Drives: 2015 6MT YMB M3, 1974 Corvette
AIRPOWER
06-29-2015, 09:58 AM | #68 | |
Rep 1,812
Here is my question - If it can cause damage if your tank goes below 1/4, then why doesn't BMW make the gas gauge go up up 5/4? That way, you can use a full tank of gas and still be safe.
AIRPOWER
06-29-2015, 10:22 AM | #69 |
Rep 170
I suspect that this is a myth.
I think the car will run out of gas(coolant) well before the heat generated from such lack of coolant could cause any damage to the pump. Anecdotal evidence - I have a long commute and get the opportunity to test this fairly often.
The Black Prinz | 09E82N51 | BMW 3-Stage Intake Manifold | BILSTEIN B12 Pro-System+ | ///M Control Arms | ///M Bushing kit | ///M Strut Brace | DINAN Camber Plates & Rear Shock Mounts | ECS Performance Trailing Arms | aFe Magnum Force Intake System [Dynamic Air Scoops+Stage 2 CAI] | BMW Performance Exhaust | BMW Performance Brakes | GOODRIDGE G-Stop SS | DEPO V2 | Style 220M reps |
06-29-2015, 12:17 PM | #70 | |
TIM YOYO
1504
Rep 3,283
Drives: 2013 M3
Yes, but you see, these go to eleven. Such a great film.
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech Past: 2013 ///M3 - Interlagos Blue Black M-DCT Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport |
06-29-2015, 12:21 PM | #71 |
TIM YOYO
1504
Rep 3,283
Drives: 2013 M3
A couple of things to keep this in perspective:
1) Yes, your fuel pump should remained submerged in fuel in order to stay cool. 2) It requires far less than 1/4 tank these days. The quarter tank requirement comes from the early days of in-tank fuel pumps, and even before manufacturers started using polymer fuel tanks that can more easily accommodate a fuel pump sump that keeps the pump submerged at lower levels. 3) Everybody be cool, this is a robbery.
06-29-2015, 12:55 PM | #72 |
Rep 3,726
Drives: 2018 M2
You guys are all joking right? You should always refrigerate your gas in a large freezer and use that to fill up
06-30-2015, 05:14 AM | #73 |
Rep 18,733
I run my car well below a quarter tank all the time, my average fill up is 13 gallons, but I have hundreds of fill ups at 14+ and 15+ gallons. 286,000 on the original fuel pump...
