2010 2011 BMW 5 Series Forum F10 Adding Electronic Valve Control (M5 Exhaust on 535i) |
06-09-2016, 11:38 AM | #1 |
Rep 465
Hello,
I have a 535i that i modded with an OEM m5 muffler so I could get the quad-tip look. I love the sound it makes with the valves open so I left them permanently open with wire since the 535i doesn't have EVC. Is there any after-market EVC I can add on that I can control with a remote?
2013 F10 535i M-Sport Alpine White Oyster/Black OEM M5 Exhaust with Resonator Delete |
06-09-2016, 04:05 PM | #2 |
Rep 14,521
Yup! Here's what I'm going to do. I'm not positive if the M5 uses the same EVC tho?
http://f10.5post.com/forums/showthread.php?t=1242558
06-09-2016, 05:12 PM | #3 | |
Rep 465
06-09-2016, 10:07 PM | #4 |
Rep 14,521
I figured that since on the M5 they automatically open and close depending on aggressive you get on the throttle. If that's the case you wouldn't be able to do it wireless hence why I posted the one I was gonna get
07-23-2017, 11:18 AM | #6 |
Rep 1,155
exhaust meister
i have one its awesome... by default stays closed and functions like stock (opens above 3k rpm) however, i can open it on demand, I also programed the 2 additional buttons for my homelink to open/close the valves. |
07-24-2017, 01:41 AM | #7 | |
Rep 716
So the exhaust meister just allows you to open and close the valve right? On a 535i there is no vacuum but on the instructions from exhaust meister in my trunk there is already a vacuum switch already? |
07-25-2017, 10:53 PM | #8 |
Rep 1,155
yes i'm not sure how it works on the 535 but my 550i has a module in the trunk where i plugged the exhaust meister into...
04-25-2019, 03:00 PM | #9 |
Rep 8
Exhaust valves should be controlled by DME.
I found solution how make it work on F10 535i https://f10.5post.com/forums/showthread.php?p=24703201 |
