2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Is this Emblem normal for US models?
      12-12-2013, 01:07 AM   #1
alfred213
Drives: 2011 550
Hi. After being an E38 owner for almost 9 years, I decided to add a 2011 550 with M Sport package to the family. I love the ride, i love the car, and and everything about it. Ordered some carbon fiber emblems and was able to change the originals on the trunk and the wheels but when I took the hood/bumper one off, I noticed that it was different than what I had ordered. Instead of having the two pins on the back of the emblem, the original had two holes (see picture) and the pins were actually on the bumper/hood. I searched all over the net and all the ones I found for F10 had the pins on the back of the emblem. But when I did a search on UK sites, I found some that matched mine and they were called bonnet emblems. Is this normal? If so, where can I get a replacement emblem? Thanks in advance for your input.
      12-12-2013, 05:57 AM   #2
Grover432
Drives: 2013 535 XDrive
Have you checked with a supplier in the UK?
2013 535 X Drive, Alpine White/M Sport/Executive/Apps/Black Dakota/Fineline Anthracite
      12-14-2013, 10:00 AM   #3
TrimThis
Drives: '14 528
Had the same problem...if yours were 2 piece like my new ones you can do this. Grind the studs off, enlarge the holes to get over the car studs and test fit. My car is white, so I used some white caulk to hold in place. Good Luck
      12-14-2013, 10:29 AM   #4
RickyB
RickyB's Avatar
30
Drives: DGM 550i
^This. For most of the aftermarket pieces the front emblem has to be modified. You just grind down the two pins and I used 3M double sided tape and it hasn't moved in two years.
DGM 550i
      12-15-2013, 10:48 AM   #5
dpouncey
DINAN free flow/BMS stage 2/ STIR PLUS- AL Priorit
Drives: 2011 BMW 550I m sport
Dinan badge is free when you car gets 10 pts., on the Dinan website you can see the value of each modification
      01-10-2014, 12:45 AM   #6
alfred213
Drives: 2011 550
Thanks guys. got it. Here is how it looks
