2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum HID for Fogs
      03-26-2014, 07:45 PM   #1
paul223
paul223's Avatar
Drives: F10
HID for Fogs
I installed DDM H11 HIDS 35W with error eliminator for Fogs, but It does not light up. It flashes like fire truck than shuts off after trying few times. Sometimes it does come on. Anyone with similar situation or suggestion?
update - if you hids as your fog, and if it flickers, here is the trick. press the ignition button once, do not turn on engine, then turn the light switch to either left for or right just to turn or lamp, now hit the fog switch, it should come on without flickering, finally turn on your engine. works everytime for me.
      03-26-2014, 09:42 PM   #2
gtmassive75
gtmassive75's Avatar
361
Drives: G05 X5,G20 M340,Infiniti Q50RS
Junk your DDM and get TRS.. http://www.theretrofitsource.com/hid...l#.UzOPvK1dX-A
I had the same issue..there's a ton of threads on this topic
2020 G05 MSport 40i--Phytonic Blue Metallic/Vernasca Coffee Leather/Multi Contour SeatsTrim/Executive Package/MSport Brakes/Icon Adaptive Led HeadlightsW/Laserlight/Harman Kardon/Heated Front Seats Armrests & Steering
      03-26-2014, 10:59 PM   #3
paul223
paul223's Avatar
Drives: F10
Thanks. I have ddm on tundra been using it for three years no problem. I will try this brand.
      03-27-2014, 06:04 AM   #4
gtmassive75
361
i use DDM on my maxima no issues..but these BMW only wants brand name stuff.. meaning empty your pocket..
      03-27-2014, 09:10 AM   #5
paul223
paul223's Avatar
Drives: F10
Yup , now I gotta buy another kit.
      03-27-2014, 10:55 PM   #6
Bobby_Drake
Bobby_Drake's Avatar
390
Drives: '16 X5M
+1 for TRS. I've had my HID fogs for over 1 yr now. ZERO issues, flickering, etc.
      03-27-2014, 11:50 PM   #7
twelve535i
twelve535i's Avatar
Drives: 2015 X5 35i M Sport
My TRS kit had issues. Maybe it was just a defective ballast, but I gave up on HID kits all together and got LED fogs.
I'm not sure the light output is the same, but the headlights light do a pretty good job at lighting the path ahead, even when the fogs are off.
      03-28-2014, 01:16 AM   #8
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
331
Drives: 2020 M8 & 2022 X& M50i
I think I'm going to order this,
especially now my fogs go on when I unlock the car, since I coded.
Is install ready?
      04-01-2014, 11:22 PM   #9
twelve535i
twelve535i's Avatar
Is install ready?
If you're car is coded so that the fogs come on when unlocking the car, the HID fogs will blink/flicker if you turn on your engine before the fogs and halos automatically power down.
      04-01-2014, 11:56 PM   #10
MELLOWYELLOW06
331
Soo shall I get led instead?
      04-02-2014, 09:06 AM   #11
paul223
paul223's Avatar
Drives: F10
How much for LEDs?
