2010 2011 BMW 5 Series Forum F10 Anyone successfully coded F10 in the UK? |
09-21-2017, 03:18 PM | #485 |
Rep 32
So it is not possible to code LDW , i thought that you maneged to code it reading the first pages of this treath ? thank you because you are the first that givves me a straith answer on this. Others say it is possible to code it without the vibraiton motor in the steeringwheel others say it is possible but you get error messages and some say they coded it on there cars without problem. so did not knowh what to believe
Thank you i will stop searching for more readings on this subject. My car is from 2016 but i dont have the options here below on my HBT navi pro. - Route Magnet (What is Route Magnet ?) - Route Simulation : I understand this you have this on a Garmin,TomTom - Avoid Route ( not taking that route i think ) - Auto Zoom SatNav maps ( I dont think i have that eather ) Can i code these things ? Thank you Gspannu |
09-21-2017, 07:18 PM | #486 | |
Rep 1,207
I tried but couldn’t get through; and eventually it dawned on me that without the steering vibration motor, the effort wasn’t worth it. Other options you have mentioned can be coded. Route Magnet: This allows you to force navigation via a particular road, almost like a waypoint without having to set separate destinations. Useful in certain situations where you want to reach your destination but go via certain road and the satnav does not route via that road. Avoid Route: The opposite of the above. Don’t go through a certain area. Useful if you know there are permanent roadworks or closures in an area, but the satnav routes it via that road/ area. Route simulation: Provides an overview of the route but in an animated fashion. You can choose the speed of playback so it gives an idea of the overall complexity of the route. It’s a great gimmick to show off, not much real world use - I think. Auto Zoom: Does not work on all cars. Depends what f/w version you have, but give it a try. It might work. Once coded, you need to select the zoom level as auto for this to work - that’s what I recall. I haven’t coded my F10 for a while, so am forgetting a few things. Enjoy !
09-22-2017, 04:59 AM | #487 |
Rep 32
LDW
Hello Gspannu.
Thank you for the information , i will wait and see if LDW is possible to code in the future.. Do you now the codes for thesecdings ? - Route Magnet (What is Route Magnet ?) - Route Simulation : I understand this you have this on a Garmin,TomTom - Avoid Route ( not taking that route i think ) - Auto Zoom SatNav maps ( I dont think i have that eather ) I dont find them in the cheats. Thank you . |
09-22-2017, 05:08 AM | #488 |
Rep 5,050
IIRC there was an Auto Zoom on my old CIC but it was a bit unconventional because it zoomed to show the whole route so, if you navigated from Aberdeen to Penzance, it would start by showing the whole country and slowly shrink to just showing Penzance by the time you got there. It was selected by zooming the map out as far as possible to Auto, but it was a complete waste of time unless you just want the Sat Nav as an ornament.
09-22-2017, 06:00 AM | #489 | |
Rep 1,207
09-23-2017, 05:35 AM | #491 |
Rep 1,207
09-24-2017, 02:03 AM | #493 |
Rep 267
M140i LCI-2 is the 16th BMW since 1977 ....
320i *2, 323i, 520i *2, 540i, 535i, 840i, E36 M5, 328i, 530i, 320d, 535d, M135i, M140i * 2 |
09-24-2017, 01:24 PM | #494 |
Rep 32
Easy Entry Seat
Hello ..
Are there people who have code the EASY ENTRY SEAT ? what thous it exactly means and how thous it works? What do i have to code exactly ? Thank you. |
09-24-2017, 05:33 PM | #495 | |
Rep 1,207
EINAUSSTIEGSHILFE > Modus_FA -> Modus_FA_SLV GENTLEMAN > nicht_aktiv -> aktiv EAH_VERFAHRWEG_SLV_PHYS > 00,3C (00,60mm) -> Set to what you like Essentially, if you have full electric seats - this feature allows easy exit. After driving to a stop, you shut down the car, you open the door; and the seats move backwards (value = 3C hex= 60mm) and allow for an easier exit.
09-25-2017, 02:07 AM | #496 | |
Rep 32
Thank you. |
09-25-2017, 04:37 AM | #497 |
Rep 1,207
09-26-2017, 09:08 AM | #498 | |
Rep 32
EINAUSSTIEGSHILFE > Modus_FA -> Modus_FA_SLV GENTLEMAN > nicht_aktiv -> aktiv EAH_VERFAHRWEG_SLV_PHYS > 00,3C (00,60mm) -> Set to what you like and everything when fine , just had to play with the Distance Values mm Inches Hex 100 3.93701 00,64 90 3.543309 00,5A 80 3.149608 00,50 70 2.755907 00,46 60 2.362206 00,3C 50 1.968505 00,32 40 1.574804 00,28 30 1.181103 00,1E 20 0.787402 00,14 10 0.393701 00,0A 0 0 00,00 to find the right distance that the seat wil move backwards. But did not find SM[6e] for the passenger in the SM module. But thank you anywhyay. |
09-29-2017, 02:48 AM | #500 | |
Rep 1,207
09-29-2017, 01:59 PM | #501 |
Rep 32
09-29-2017, 02:34 PM | #502 |
Rep 32
gspannu here is my CAFD file i only find 1 SM module
Here is a link to my CAFD file https://mega.nz/#!qVhEXDSI!I3wNj-0sP...1WanKgFISbtQXE the key !I3wNj-0sP8Knd0Jc0Lso1hFH7tt3N1WanKgFISbtQXE Last edited by Tony_ca1; 09-29-2017 at 02:39 PM.. |
09-29-2017, 04:35 PM | #503 |
Rep 32
Rear view camera..
Hello..
I code my rear view camera to always on werte ff And it works but if you drive faster then 30KM the camera will not com on anymore .. What did i do wrong?? T tought we activate the camera at all speeds ? Thank you. Last edited by Tony_ca1; 10-02-2017 at 06:21 AM.. |
10-01-2017, 11:58 AM | #504 |
Rep 7,000
I have the Bimmer code app with expert mode which has been very good and I have coded quite a lot that's actually useful.
However I cannot work out how to fold the wing mirrors when the car is locked. It will fold them if I hold the key fob or the comfort access on the handle for a few seconds but want it to fold them on lock. Can anyone advise? Thanks |
10-01-2017, 12:31 PM | #505 | |
Rep 96
Basically when you hold the lock button, it usually takes a couple of seconds to start folding, but the delay can be programmed. I have mine set to around 0.5 seconds.
F10 LCI 535d (313PS) M Sport
10-01-2017, 01:01 PM | #506 |
Rep 7,000
Do you have the modules and steps etc?
