2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Brake upgrades from other BMW models on F10
      08-22-2018, 01:32 AM   #45
jashansingh
Drives: 2014 535i
I recently flashed my 535i with BM3! It is freaking awesome, a whole new beast! But the brakes feel so weak right now. The original pads that came with the car have lasted me 72k miles and maybe another 5 -10k. If I have to get the set up you have with 20 inch wheels. What would you recommend and where to find it? Please let me know should I just get the zimmerman rotors? I never worked on the brakes and probably will take it to a shop. Just don't want to get ripped off.
      08-24-2018, 11:04 AM   #46
DARKKN1GHT
Drives: 535XI
If anyone is interested in buying my brake setup I am thinking of selling the complete package, putting the car back to stock and selling it. Included would be front X6M brembo calipers, mounting hardware, ceramic pads, rear 550i calipers, ceramic pads and one piece steel rotors front and rear. The calipers were completely sandblasted rebuilt and repainted prior to install. The whole setup has less than 150 miles on it. The brake were painted burnt copper and clearcoated with PPG clear.
      08-27-2018, 10:48 AM   #47
Jamrockbwoy
Drives: 2015 550i xDrive
I would be interested in just the calipers.
Instagram @_gr8dane
2015 550xi - current
2015 428xi - retired
2010 328xi LCI retired
      08-27-2018, 09:14 PM   #48
sweettalker
Drives: Vrooom
What is the price range u r looking for. And also where ru located. Would u sell just fronts
      09-03-2018, 11:20 AM   #49
wtlb
Drives: 5
Would this break set from the 750 work on a 528?
      09-04-2018, 06:01 PM   #50
philipf10
Drives: bmw m5
Hello
I have a 2014 F10 528i. I am trying to put a bigger drilled rotor and possibly a bigger caliper like M5 caliper. What do you recommend me ?
thanks
      09-06-2018, 12:25 PM   #51
DARKKN1GHT
Drives: 535XI
If anyone is interested, I am looking to get around 1300 for the entire setup front and rear with everything included. There is less than 100 miles on everything.
      09-28-2018, 12:18 AM   #52
DARKKN1GHT
Drives: 535XI
Still have the entire kit for sale. 1200 shipped.
      10-04-2018, 04:27 PM   #53
LucasL
Drives: E87 120d MS & F31 320D MS
A friend of mine got this setup on his 535d. Porsche Panamera Calipers + BMW 374x36mm discs with custom adapters.
      10-04-2018, 10:45 PM   #54
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Looks great!
Are those rotors from E60 M5?
      10-17-2018, 08:16 AM   #55
f10_will
f10_will's Avatar
Drives: F10 535 msport xdrive
M6 brakes on my 535 front and rear
John H.230.00
      10-18-2018, 12:22 PM   #56
Jorjel
Drives: E90 LCI 323i
Is the 750xi US equipped with the 374x36? Also, will those clear 18" OEM wheels?
      10-18-2018, 01:00 PM   #57
Gixxer550i
Drives: 2015 550i
2023 BMW G05  [0.00]
Anyone have slotted rotors setup in a 550xi 19 or 20in?
      10-18-2018, 08:35 PM   #58
addy27
Drives: F10 550i
In the US, only the 760 is equipped with 374x36 OR ALPINAs (B6 and B7)..
E60 M5 also has 374x36 BUT the center is bigger and overall pad contact area is smaller on them as compared to the ALPINA/760 calipers. Though, not sure if the caliper is a direct fit from E60 M5..
John H.230.00
      10-19-2018, 01:12 PM   #59
Jorjel
Thanks for the info. 346 doesn't sound that bad for my 528xi
Looking to upgrade the rear as well from the current 330x20 to the 345x24
      10-20-2018, 02:41 PM   #60
Bozman52
Bozman52's Avatar
71
Drives: 2015 M5
Can you elaborate on how you got M6 brakes to fit on your F10? These can't be a direct fit . . .
      10-24-2018, 06:56 AM   #61
Bozman52
Bozman52's Avatar
71
Drives: 2015 M5
My wheels are 20 inch. Cant confirm whether oem 19s would fit since the calipers are huge.
Yep direct fit. I just used a custom made 4mm thick stainless steel spacer/washer that fit between the caliper and knuckle, and longer bolts. The bolts I used were oem BMW subframe bolts, which were a bit long but I was able to shorten em. I had to order 25 of these spacers so if anyone wants I can sell them some.
My calipers were bought used on ebay, and I stripped them down completly ,rebuilt them with new seals and dust boots.
DARKKN1GHT, If you have any additional pics or insights from your X6M install, I'd love to know more. What did you do about the caliper carriers? Did your existing carriers fit the X6M brakes, or did you need to get X6M carriers as well?
      10-24-2018, 01:08 PM   #62
Lbredefe
Drives: 2012 740li
Question
DARKKN1GHT or anyone else who can answer please, I am looking to install 2012 FRONT X6M calipers on my 2012 740Li.
  1. ) Will I need anything besides the calipers?
  2. Can I run these bigger calipers without buying the X6M's larger 395x36 rotor?
  3. IF I do need the larger rotor, will I need to put a spacer on the X6m calipers where they mount? what size would I need? 4mm?
  4. is there anything else I will need to buy to make a bolt on swap work? aside from brake fluid. I am one of the few people who is trying to upgrade the 7 instead of using the 7 brakes on the 5.
      10-24-2018, 03:05 PM   #63
Lbredefe
Drives: 2012 740li
Talking
how did you get the x5m rotors to sit on the hub given they are 74mm vs the f10 72.56mm bore? also I want to buy a set of those spacers to do x6m rotors and calipers on my F02
      10-26-2018, 05:36 AM   #64
Bozman52
Bozman52's Avatar
71
Drives: 2015 M5
I'm glad to see there's some traction here for this mod from others! Regarding your query, I believe that DARKN1GHT kept the F10 rotor (or maybe upgraded to the 550/750/760 rotors that bolt on directly) and just used the X6M calipers. I don't think he retrofitted the X6M rotor onto his car.
      10-26-2018, 03:32 PM   #65
DARKKN1GHT
Drives: 535XI
Sorry guys sold the car and the brakes. I will post part numbers when i get a chance. I used x6m front rotors,pads and calipers. Brake lines are stock and bolt up to the caliper. Only thing needed for fitment is custom 4mm spacers to offset the caliper outward and longer bolts due to the spacer.
      10-29-2018, 05:44 AM   #66
Bozman52
Bozman52's Avatar
71
Drives: 2015 M5
I've had some PMs with DARKKN1GHT, so I thought I'd post some of his responses here so that all could chime in with their thoughts. This X6M brake mod is something I'm seriously considering doing, so I want to be absolute sure that I have all the info before I start buying expensive parts! The following are comments from DARKKN1GHT:
F10 will accept front x6m rotors without issues, the hub bore will not matter as that is integral to the hub of the car and the rotor bore hole is the same across all BMW models. The caliper also mounts like factory but it doesn't center over the rotor like OEM due to the x6m having a different knuckle. The spacer is meant to push the caliper away from the knuckle and center it. It is a 4mm spacer from my research, measuring and trial. Ive had the car up to 130mph plus. The bolts are just longer ones than stock due to the spacer which now takes up space between the mounting surface. The bolts I used were from the front subframe due to them being the same design, rating, but they are too long stock so you will need to trim them.
I used E71 rotors but the F86 is interchangeable as well. My reason was due to cost, as the drilled 2 piece are expensive. E71 guys frequently upgrade their rotors to the new ones so that's how I know it all fits.
John H.230.00
