2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Creaking/squeezing front suspension BMW F10
      01-19-2024, 11:14 AM   #23
kohsin
Drives: 2013 F10 550ix
I had the same issues, especially when slowly getting over the bumps. It turned out to be the upper control arm bushing. I spray the silicone to all the rubber bushings and the noise is gone.
      01-20-2024, 10:03 AM   #24
zvery777
zvery777's Avatar
Drives: 2021 M550
What silicone are you guys using for this?
      01-20-2024, 12:12 PM   #25
kohsin
WD-40 silicone lubricant spray..
      01-27-2024, 11:37 PM   #26
poverty.f10
DIY Mechanic
poverty.f10's Avatar
Drives: 2012 BMW 535i xDrive
Originally Posted by jpophammer View Post
sorry for reviving an old thread but I just found the solution to my creaking noise in my front end and wanted to share!
After digging into what the most annoying sound my M5 has ever made, I was convinced it was the lower front control arm... well, I jacked the front of the car up and the wheel had NO play at all...
reached into the spring/ strut area and pulled the little rubber bushing and plastic tube down, sprayed it with silicone lube. SQUEAK IS GONE!
Thank god I didnt go out and just buy parts for it...
Best of luck to everyone and hopefully you'll be able to fix the noise with a few bucks!
So you sprayed above the bump stop and dust cover?
You can live in a car but you can’t race a house.
      01-28-2024, 07:17 AM   #27
jpophammer
Drives: 2013 F10 M5
Basically the top of the bump stop and inside the dust cover. The rubber on the bump stop is old and after taking it through the car wash one time, it must have removed oils or something to make it squeak. I’ll admit, this is a cheep fix and not a proper fix. But two weeks later… I still have no squeak or creaking sounds
      01-29-2024, 11:48 AM   #28
Hornet-01
Hornet-01's Avatar
Russia
122
Drives: BMW 550 xdrive
2011 550ix  [9.50]
This is a temporary solution... wouldn't it be easier to replace the spare part with a new one?
      01-31-2024, 06:45 AM   #29
Nuttbusta
Drives: BMW F01
Theres a lot to be said for temporary solutions. However much you do or do not buying a little extra time, proving beyond doubt what and where the problem lies is completely invaluable
      01-31-2024, 11:17 AM   #30
kohsin
Well..this temporary solution has been in place for two years .
Eventually it will need to be replaced but visual inspection during tire rotation showed no sign of breaking down so I am fine with it.
      02-01-2024, 09:38 AM   #31
Hornet-01
Hornet-01's Avatar
Russia
122
2011 550ix  [9.50]
2 years... unexpectedly. Cool!
