2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes SHOW OFF YOUR 20"s
      01-22-2023, 07:16 AM   #155
Double Nickel
Double Nickel's Avatar
Drives: BMW F10
2015 BMW F10  [10.00]
Originally Posted by Blue Angel View Post
Your fronts might need a spacer to clear the suspension upright. Your rears are going to poke by as much as 20mm unless you go stancenation with negative camber and/or super stretched tires.
I got the H&R VTFcoils hope front clear, and my car is not xdrive if that makes a difference. still dont know bout front tires but im going triple nickel g2 305/30/20 in the back.
      01-22-2023, 12:18 PM   #156
brad850csi
Drives: 16 F13 M6 Comp
Originally Posted by Double Nickel View Post
19×9.5 +35f/ 20×10.5 +22R Artisa Elder, but look at that fittment with the stock winters tho. Idk What tire size yet,
I'm thinking 265 or 275 is what you'll need to run on the rear, then either 20 or 30mm narrower on the front to match the stretch. Keen to see the end result!
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
      01-22-2023, 01:32 PM   #157
Double Nickel
Drives: BMW F10
Why not a 295 or 305 Nitto g2?
      01-22-2023, 02:34 PM   #158
zener
BMW enthusiast since 2004
343
Drives: E65 730d, F10 520d, E34 520i
So rear is 20x11 ET37 + 5mm spacer? 11" wheel effectively ET32, the wheel might be touching the fender if the tire doesn't! Good luck!
This is without spacer. Tire clears easily and wheel by just. But I'm not going that low... Just tested it with lift.
      01-22-2023, 03:18 PM   #159
Blue Angel
Blue Angel's Avatar
Drives: 2011 323i and 2016 535d
Nice! I think the 5mm spacer would make it touch for sure.
On your fronts, is it ET37 including the 17mm spacer, or ET20 including the spacer?
      01-22-2023, 11:45 PM   #160
zener
343
Et20 with spacer.
      01-23-2023, 08:36 PM   #161
brad850csi
People running 34mm offset rear wheels can barely get 295mm tyres on there so a 20mm offset wheel will mean you'll need to go down to about a 265 or so. A 295 or 305 will absolutely not fit
      01-24-2023, 09:52 AM   #162
Double Nickel
Drives: BMW F10
Challenge accepted
      01-25-2023, 05:12 AM   #163
Blue Angel
Blue Angel's Avatar
Challenge accepted
Allrighty then, 305 on ET20, let’s see it!
      02-01-2023, 06:51 AM   #164
lucasfaria1994
Portugal
Drives: BMW F11, Mini R57
Hey guys, my BMW F11 2011 (520 diesel, RWD) with 20 inch wheels. Stock height, factory spec tyres. The rear sits flush, the front could use with a 5mm spacer.
(Sorry for European measurements)
Specs:
Wheels: Aversus Kasia
Front: 245/35R20 20x9 ET35
Rear: 275/30R20 20x10.5 ET42
cdmulders326.50
r2dmax58.00
      02-28-2023, 05:02 PM   #165
Hellboy550i
Drives: BMW 550i
Originally Posted by lsturbointeg View Post
don't mind me i'm just being a post whore!
What’s the specs here for this wheel? Do u use spacers too. ?
      03-01-2023, 03:21 PM   #166
cb2004mj
Drives: 2014 535d
Here's mine. 535d rwd. All the deletes and mods. Bc coilovers for over 70k miles.666m wheels 20x9.5 front 20x10.5 rear. 245/40 front 285/30 rear. Forget offset. Zero rub even with an iron block motor and a trans in the trunk and three full grown adults in it.
      03-01-2023, 10:04 PM   #167
Blue Angel
Blue Angel's Avatar
666M are 20x9 ET29 Front and 20x10 ET40 Rear, according to this:
https://www.carsaddiction.com/en/wheels/bmw/style-666
Looks good! Rep the diesel crowd!
      03-02-2023, 08:26 AM   #168
cb2004mj
Drives: 2014 535d
Thanks bro, yea these are aftermarket 666m wheels not OEM. I'm baller on a budget, couldn't justify the 3500-4k dollar cost of OEM 666m wheels on a daily. I'd hate to road trip and hit a pothole and damage a 1k+ wheel on a 18k dollar car lol. But these are for sure 9.5 wide front and 10.5 rears. It's been almost two years so I'd have to dig to find the offset
      03-02-2023, 10:20 PM   #169
Blue Angel
Blue Angel's Avatar
Aha! Exposed! Lol
No sweat man, I totally get it. Either way your car looks great and that’s the point, right? I can’t recall seeing that wheel on an F10 before. It looks great!
      03-25-2024, 06:39 PM   #170
Duck70
Drives: 2008 BMW 335xi
Originally Posted by AWF87M2 View Post
My F10 on BBS CIR 20x9 et25 front and 20x10.5 et35 rear lowered on acs springs. Sits perfectly flush with fender no spacers needed.
Looking at basically the exact same setup but with 265 up front and 295 in the rear, you think those will fit?
Also, did you do anything with your rear camber? I would assume those 10.5" rears would stick out further than yours are...
      03-27-2024, 04:09 PM   #171
HI_F10
Drives: 2011 535i
HRE FF04
20 x 9.5 ET 20
20 x 10.5 ET 26
      03-29-2024, 06:36 PM   #172
Blue Angel
Blue Angel's Avatar
Originally Posted by HI_F10 View Post
HRE FF04
20 x 9.5 ET 20
20 x 10.5 ET 26
More pics! Tire sizes?
HI_F1064.00
      03-29-2024, 09:22 PM   #173
HI_F10
Drives: 2011 535i
front 245/35
rear 285/30
      04-06-2024, 01:44 AM   #174
Duck70
front 245/35
rear 285/30
Do you get any rubbing? Are you on stock suspension or coilovers? Stock camber?
      04-06-2024, 07:07 PM   #175
HI_F10
Drives: 2011 535i
on BC coilovers with no rubbing. i did do the M5 brake conversion
Duck708.00
      04-07-2024, 10:38 PM   #176
Duck70
Nice! I have been waffling on buying a used set of BBS CI-R 20" (9", 10.5") for a bit now and am just trying to get any and all information about how these things would fit.
Does the M5 brake conversion help at with additional clearances and fitment?
HI_F1064.00
