2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Anyone mounted original M5 343M 20" rims on an F10/F11
      12-19-2023, 06:19 AM   #177
Blue Angel
Blue Angel's Avatar
Drives: 2011 323i and 2016 535d
If I was running 343M I’d be doing the same setup as Unspec. His car looks fantastic!
Unspec1301.00
      01-13-2024, 11:49 PM   #178
SocomCA
Drives: BMW M6
I can confirm that on a LCI F10 550i xdrive, the m343 wont clear the caliper without a spacer. But any spacer under 12mm causes a vibration, as a fyi
      01-14-2024, 02:00 PM   #179
Blue Angel
Blue Angel's Avatar
Sounds like something else might be going on.
      01-26-2024, 08:45 PM   #180
SocomCA
Drives: BMW M6
No, the spacers under 12mm arent hub centric so they cause vibrations
      01-27-2024, 01:04 PM   #181
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
That is not necessarily true. You can run 3mm spacers without any vibrations.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      01-27-2024, 08:47 PM   #182
Blue Angel
Blue Angel's Avatar
And I use hubcentric 10mm spacers with my 408M fronts.
